Exim 4.94 update causes email temporary rejects
PurpleAlien
I've just run an update on directadmin which also upgraded Exim to 4.94.
In the exim mainlog I'm seeing the following for all incoming mails:
temporarily rejected RCPT <xxxxx@yyyyy>: failed to expand "${if exists{/etc/virtual/${domain}/aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/aliases}}}}": NULL
In /var/log/exim/paniclog I have these for each domain:
Tainted filename for search: '/etc/virtual/yyyy/aliases'
I've rerun ./build exim and ./build exim_conf and also ./build rewrite_confs but the issue remains. There were no issues with the previous version.
Any ideas?
Yes. Otherwise I would not have had the new version of Exim. Ran it several times since as well, just in case.
Any custom code in exim configuration? I don’t recall seeing anything like this with newest versions. If the license has support included - you may open a DA ticket with access to the system.
No, no custom code. Falling back to 4.93 and everything is fine again. I'll check the support...
Got the same, Tainted filename for search: '/etc/virtual/yyyy/aliases' but only on servers with MagicSpam includes it looks like.
I guess they might not be compatible with exim 4.94 then :)
Same Issue here
" Tainted filename for search: '/etc/virtual/mydomain.com/majordomo/list.aliases' "
any update on this ?
I solved my problem with started again with these this time use build set_fastest. and it solved.
build says yellow OK when he can not connect "A" server but he
./build set_fastest
./build set exim yes
./build set eximconf yes
./build set eximconf_release 4.5
./build set spamassassin yes
./build exim
./build exim_conf
Yes, that might be it. It's on Debian 8 LTS (which is supported until the end of the month). We did not update directadmin on the replacement for this one yet because this issue popped up. I didn't think this would be related, and the relevant config comes in through directadmin.
