epadicom
Previously I used openlitespeed on the server using the directadmin 1.61.3.
But for some reason, then I changed the web server to nginx_apache.
After successfully installing and rebuilding nginx_apache using custombuild, my website became an error "503 Service Unavaliable"
The following contents of the error_log file # tail -f /var/log/httpd/error_log
./build rewrite_confs notifications
Any suggestions and solutions regarding my issue?
Thank you
	[Thu Jul 02 01:06:33.908877 2020] [:notice] [pid 2985:tid 140117201598592] mod_ruid2/0.9.8 enabled
[Thu Jul 02 01:06:33.912448 2020] [mpm_event:notice] [pid 2985:tid 140117201598592] AH00489: Apache/2.4.43 (Unix) OpenSSL/1.0.2k-fips configured -- resuming normal operations
[Thu Jul 02 01:06:33.912508 2020] [core:notice] [pid 2985:tid 140117201598592] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Thu Jul 02 01:07:01.926883 2020] [mpm_event:notice] [pid 2985:tid 140117201598592] AH00493: SIGUSR1 received.  Doing graceful restart
[Thu Jul 02 01:07:01.955805 2020] [ssl:warn] [pid 2985:tid 140117201598592] AH01909: localhost:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 02 01:07:01.956837 2020] [ssl:warn] [pid 2985:tid 140117201598592] AH01909: www.example.com:8081:0 server certificate does NOT include an ID which matches the server name
[Thu Jul 02 01:07:01.957505 2020] [lbmethod_heartbeat:notice] [pid 2985:tid 140117201598592] AH02282: No slotmem from mod_heartmonitor
[Thu Jul 02 01:07:01.957547 2020] [:notice] [pid 2985:tid 140117201598592] mod_ruid2/0.9.8 enabled
[Thu Jul 02 01:07:01.957790 2020] [mpm_event:notice] [pid 2985:tid 140117201598592] AH00489: Apache/2.4.43 (Unix) OpenSSL/1.0.2k-fips configured -- resuming normal operations
[Thu Jul 02 01:07:01.957805 2020] [core:notice] [pid 2985:tid 140117201598592] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
	[root@da-mun01 custombuild]# ./build rewrite_confs
Checking to ensure /etc/httpd/conf/ssl.crt/server.ca is set.
Using 164.68.124.72 for your server IP
Failed to restart php-fpm74.service: Unit not found.
Failed to execute operation: No such file or directory
Failed to restart php-fpm73.service: Unit not found.
Failed to restart php-fpm72.service: Unit not found.
Failed to restart php-fpm71.service: Unit not found.
PHP has been secured.
Restarting php-fpm74.
Restarting php-fpm73.
Restarting php-fpm72.
Restarting php-fpm71.
Thank you
