Something wrong with recent DA install:
What are the permissions on the backup directory?
ls -l /home/admin
drwx--x--x 2 admin admin 4096 Jul 3 16:44 admin_backups
Checking the code, there are only 2 function calls that could return that error.
Either a stat() call, or opendir().
I've updated the DA code to include debug output, exactly level 433.
1) Grab the latest pre-release binaries.
2) go to the page in 2222 so that you're only 1 click away from generating that error.
3) run DA in debug mode 433
4) click the button to duplicate the error.
We'd be looking for either:
Sys::getDirFiles:%s: stat error as euid=%d: %s
or:
Sys::getDirFiles:%s: opendir error as euid=%d: %s
where the %s and %d bits would be replaced with relevant information.
The euid should be the admin uid from the "id admin" call. If it's a different number, then that's likely why.
Also makes sure that the:
ls -lad /home/admin
is 711.
Thanks John,
here is the result:
Debug mode. Level 433
DirectAdmin 1.61.3
Accepting Connections on port 2222
/CMD_JSON_LANG
GET string: json=yes&domain=domain.fi&initial=no&request=global&dynamic=yes
Checking referer https://x.x.x.x:2222/?redirect=yes to x.x.x.x:2222
auth.authenticated
User::deny_override:/CMD_JSON_LANG: call_level=2, depth1: aborting due to do depth
User::deny_override:/CMD_JSON_LANG: call_level=1, depth2: aborting due to do depth
User::deny_override:/CMD_DOMAIN: call_level=2, depth1: aborting due to do depth
User::deny_override:/CMD_DOMAIN: call_level=1, depth2: aborting due to do depth
Command::doCommand(/CMD_JSON_LANG)
Command::doCommand(/CMD_JSON_LANG) : finished
Command::run: finished /CMD_JSON_LANG
/CMD_AJAX_SEARCH
GET string: json=yes&search=resto&users=yes&admins=yes&resellers=yes&domains=yes&email=yes&ftp=yes&db=yes&search_0=1&search_1=1&search_2=1&search_3=1&search_4=1&search_5=1&search_6=1&search_7=1&search_8=1
auth.authenticated
User::deny_override:/CMD_AJAX_SEARCH: call_level=2, depth1: aborting due to do depth
User::deny_override:/CMD_AJAX_SEARCH: call_level=1, depth2: aborting due to do depth
Command::doCommand(/CMD_AJAX_SEARCH)
Searching for 'resto'. usertype=3 users=1 resellers=1 admins=1 has_expired=0
Command::doCommand(/CMD_AJAX_SEARCH) : finished
Command::run: finished /CMD_AJAX_SEARCH
/CMD_SITE_BACKUP
GET string: json=yes&domain=domain.fi&ipp=50
/CMD_SITE_BACKUP
auth.authenticated
auth.authenticated
User::deny_override:/CMD_SITE_BACKUP: call_level=2, depth1: aborting due to do depth
User::deny_override:/CMD_SITE_BACKUP: call_level=1, depth2: aborting due to do depth
Command::doCommand(/CMD_SITE_BACKUP)
Sys::getDirFiles:/home/admin/backups: stat error: No such file or directory
Dynamic(api=0, error=1):
text='Cannot Execute Your Request'
result='Unable to read backups directory<br>
Command::doCommand(/CMD_SITE_BACKUP) : finished
Command::run: finished /CMD_SITE_BACKUP
It seems that for some reason it is looking for /home/admin/backups and not /home/admin/admin_backups ?
CMD_SITE_BACKUP is the "User Level" backup tool.
You'd want to make your way over to the "Admin Level" first, then access the "Admin Backup/Transfer" tool.
Hi.
Im on the Admin level and I get to that location ( CMD_SITE_BACKUP ) if I use the Search function and type in restore.
The only result I get is "Restore backup" and that gives that error.
If I go straight to Admin Tools/Admin Backup (Transfer)/Restore and pick up the backup file to be restored from there I get this:
Unable to extract backup/user.conf from /home/admin/admin_backups/user.admin.name.tar.gz
Error while extracting backup/user.conf to /home/admin/admin_backups/name as admin : tar (child): /home/admin/admin_backups/user.admin.name.tar.gz: Cannot open: Permission denied
tar (child): Error is not recoverable: exiting now
/bin/tar: Child returned status 2
/bin/tar: Error is not recoverable: exiting now
-rw-r----- root root /home/admin/admin_backups/user.admin.name.tar.gz
Cannot read /home/admin/admin_backups/name/backup/user.conf : Unable to open /home/admin/admin_backups/name/backup/user.conf for reading.
The owner obviously needs to be admin not root.
" The owner needs to be admin. "
Thanks! Changed the owner to admin with chown, worked.
However I still get still weird looking search results when searching available functions. Take a look.
That's what mine looks like. Are you not finding what you are looking for? Maybe you need a different search term. Personally I just use the menu since all of the functions are there.
Here is how it should look like:
I only have 2 running evolution skin, one is fairly new and one is old and both look like jet1972's. So I guess its a bug somewhere.
Really weird stats, server date is July 5th 2020 (5.7.2020):
Likely related to wrong date format I guess. May you paste the output of /CMD_BANDWIDTH_BREAKDOWN?json=yes&year=2020&user=admin&ipp=500 ?
Sure:
2020 03 08
da"7652123"
day"08"
email"0"
email_count"0"
email_count_incoming"0"
email_count_outgoing"0"
ftp"0"
http"824"
http_homedir"0"
http_ul"353"
imap"0"
month"03"
other"0"
pop"0"
total"7652947"
year"2020"
2020 03 09
da"5139743"
day"09"
email"511410"
email_count"116"
email_count_incoming"114"
email_count_outgoing"2"
ftp"0"
http"3458211"
http_homedir"0"
http_ul"535443"
imap"1132129"
month"03"
other"0"
pop"0"
total"10241493"
year"2020"
2020 04 10
da"1702239"
day"10"
email"684942"
email_count"162"
email_count_incoming"162"
ftp"0"
http"1245059"
http_homedir"0"
http_ul"80565"
imap"0"
month"04"
other"0"
pop"0"
total"3632240"
year"2020"
2020 06 16
da"1390602250"
day"16"
email"5282"
email_count"6"
email_count_incoming"6"
ftp"0"
http"0"
http_homedir"0"
http_ul"0"
imap"0"
month"06"
other"0"
pop"0"
total"1390607532"
year"2020"
2020 06 21
da"0"
day"21"
email"327789"
email_count"50"
email_count_incoming"50"
ftp"0"
http"0"
http_homedir"0"
http_ul"0"
imap"0"
month"06"
other"0"
pop"0"
total"327789"
year"2020"
2020 07 04
da"4764446"
day"04"
email"607886"
email_count"78"
email_count_incoming"78"
ftp"0"
http"0"
http_homedir"0"
http_ul"0"
imap"0"
month"07"
other"0"
pop"0"
total"5372332"
year"2020"
month"0"
total
da"1409860801"
email"2137309"
email_count"412"
email_count_incoming"410"
ftp"0"
http"4704094"
http_homedir"0"
http_ul"616361"
imap"1132129"
other"0"
pop"0"
total"1417834333"
year"2020"
May you confirm enhanced shows just a single entry there? 2020 07 04
Please try pre-release for the bandwidth breakdown issue :)
