No changes have been made to perl.Did you secure your perl executable? I remember when I did that several years ago, it provided a blank screen on CSF.
/usr/local/directadmin/scripts/set_permissions.sh all
/usr/local/directadmin/scripts/set_permissions.sh all did not work.Are you sure you have CSF installed correctly, with the correct permissions? Try running the install script again, I had a problem where I had to run the following to fix the issue:
Code:/usr/local/directadmin/scripts/set_permissions.sh all
Doesn't work with any of the skins.If you switch to the Enhanced skin, is it also showing a blank page there?
yum install perl-libwww-perl.noarch perl-LWP-Protocol-https.noarch perl-GDGraph -y
wget http://files.directadmin.com/services/all/csf/csf_install.sh
/bin/sh ./csf_install.sh
Hi
Came back to this, did the original poster find a solution? I'm fairly sure it was the perl issues I ran into before, but would like to hear what happened.
Kind regards
These haven't been changed since I installed CentOS 8 a couple of months ago, so they will be set at their defaults.I assume you checked Perl's permissions?
My issue above was a bug, support informed me of the solution and it worked fine.
Permissions on /usr/local/directadmin/plugins need to be set to 711.
