Remove Openlitespeed
akadi81
I tried openlitespeed, but i want to go back to nginx_apache solution.
OS: Centos 7.
Commands used:
./build set webserver nginx_apache
./build set php1_mode php-fpm
./build set php2_mode php-fpm
./build set php3_mode php-fpm
./build set php4_mode php-fpm
./build all d
./build rewrite_confs
Everyting seemd to be ok... until restart when i saw that openlite is serving requests. Please see attachments.
Any ideea how to get rid of openlite?
Thank you.
It seems it's needed to disable openlitespeed from starting.
I used command: systemctl disable openlitespeed for centos 7 and looks fine.
Hello
Can you please have a comparison between openlitespeed and nginx_apache (esp for production web hosting servers)?
Hello
Very hard to tell, we use both on different servers and TBH i did not feel any difference however if i have to give number i say 4 to nginx_apache and 5 out of 5 to openlitespeed
But can you disable rules in modsecurity? as far as i know this option doesn't work in directadmin.
