flexjoly
We are configuring a new server for wordpress on centos8.
I think I miss something here, but I cannot get the https://hostname::2222 to work.
running:
with result:
Even put:
Even rebooted the server.... but https is still not working for DA on 2222.
The same url with http does work.
What am I missing?
Thanks in advance!
flexjoly
running:
/usr/local/directadmin/scripts/letsencrypt.sh request_single <hostname> 4096
with result:
Setting up certificate for a hostname: ******
Requesting new certificate order...
Processing https://acme-v02.api.letsencrypt.org/acme/authz-v3/*****...
Processing authorization for ******...
Challenge is valid.
Generating 4096 bit RSA key for ******...
openssl genrsa 4096 > "/usr/local/directadmin/conf/cakey.pem.new"
Generating RSA private key, 4096 bit long modulus (2 primes)
e is 65537 (0x010001)
Checking Certificate Private key match... Match!
DirectAdmin certificate has been setup.
Setting up cert for Exim...
Setting up cert for WWW server...
Setting up cert for FTP server...
The services will be restarted in about 1 minute via the dataskq.
Certificate for ***** has been created successfully!
Even put:
enable_ssl_sni=1 in directadmin.confEven rebooted the server.... but https is still not working for DA on 2222.
What am I missing?
Thanks in advance!
flexjoly
