- Feb 27, 2003
We're pleased to announce the full release of DirectAdmin 1.61.4
All changes can be found here:
https://directadmin.com/versions.php?version=1.614000
The most notable changes are below:
Features:
Bugfixes:
To update DirectAdmin, go to:
Let us know if you have any issues.
Features:
- Per-Domain php settings via GUI
- Optional zstd backup compression (instead of tar.gz or zip)
- Notices for manual suspension
- new custom template: additional_forbidden_domains.list
- User controlled ModSecurity settings
- Default change: disable_ip_check=1
- FileManager: option to not have "move to trash" checked by default
- FileManager: v2 : Major changes, OS-like feel
- LetsEncrypt: Lego dnsproviders for wildcard certs on various remote dns services
- ModSecurity scanned by Brute Force Monitor: modsec_audit.log (disabled by default)
- setup.sh to throw exit code on failure
- BubbleWrap template for LiteSpeed
Bugfixes:
- Improved error handling on large file uploads
- Set LC_CTYPE to "" for special characters
- Show fewer SSL key bit-sizes
- Improved Rspamd wildcard matching
- wp-login.php BFM multiplier from 4x to 50x
- CMD_API_POP?type=quota now uses doveadm for better performance
- FileManager to use mtime, not ctime
- /usr/local/directadmin/plugins to chmod 711
- Clear Message not showing list of auto-fill subjects
- LiteSpeed: Always define php handler
- ubandwidth (and all other u* items) =no|OFF now respected
- FileManager: Trash listing to be done based on original data, not .trashinfo file
- LetsEncrypt: delete domain.com.letsencrypt_remaining_retries after success
- Install: './directadmin i' to not install proftpd.conf. Let CustomBuild add it
- Delete php-fpmXX.conf files if php=OFF is set for the User
- Enhanced skin: revert to "en" if the translated html is missing for a custom lang (prevents "none" message)
- Optimization: string to json string
- DNS: Pointers: Duplicate records with subdomain pointer cause issues
- FileManager: action=parent_tree to respect filemanager_du=0
- doveadm expunge fails on overquota: fallback to old method
Admin Level » Licensing / Updates » Update DirectAdmin
