DirectAdmin 1.61.4 has been released
DirectAdmin Support
Administrator
Staff member
We're pleased to announce the full release of DirectAdmin 1.61.4
All changes can be found here:
https://directadmin.com/versions.php?version=1.614000
The most notable changes are below:
Features:
Bugfixes:
To update DirectAdmin, go to:
Admin Level » Licensing / Updates » Update DirectAdmin
Let us know if you have any issues.
Hi, It appears that settings are not per domain, but global.
When I set display errors on for domain1.com, it allso displays errors on domain2.com. even when I disable it explicitly for domain2.com too
Allso, when I switch domains, it does not update the contents of the page unless I refresh manualy
Further testing showed me that unless I set it on my default domain, it's not updating. It does write it into the data (domain1.com.php.ini and domain2.com.php.ini).
Probably a bug
May you create a support ticket? If no support - just PM access details and name the domain.
system.log is running full of
2020:09:19-15:30:25: Clean shutdown successful
2020:09:19-15:30:36: Clean shutdown successful
2020:09:19-15:30:40: Clean shutdown successful
2020:09:19-15:30:41: Clean shutdown successful
2020:09:19-15:30:42: Clean shutdown successful
2020:09:19-15:30:51: Clean shutdown successful
2020:09:19-15:30:55: Clean shutdown successful
As you can see, no 'exit' 'child' etc texts, only those above.
Restarting DA several times, including debugging, but no solution.
It appears to add more lines every time directadmin 'has something to do'. (think of API calls, backup, :2222 calls, and such).
I tried to use debug level 5000 but when I run directadmin b5000 I am no longer seeing those messages.
Weird .. .. .. ..
I assume this IS a bug, and it will be fixed really soon as filling up logfiles is not what we want.
Yes I can confirm it too, please fix this
Thanks for the report, sorry about that!
For the time being, I've re-pushed all binaries with the fix.
It was logging that entry after each child's exit, not just the parent (we had a major rewrite/refactor of many areas for this release).
To get it now, grab the latest pre-release binaries (which is 1.61.4 plus this fix):
I'll wait until later today or tomorrow to watch for other errors, in case there are any, saves multiple releases, and will push 1.61.5.
FYI, the compile time with the fix would be in the ballpark of:
Compile time: Sep 19 2020 at 16:03:16
Dosya yöneticisi, dosya düzenlemede Arama görünmüyor. CTRL+F search not coming out
Bulk copy and move is not done because file manager is not select all on mobile
Thank you for filemanager.
After update I can not go from file manager to home of directadmin panel.
You can, just close the tab of filemanager (because it opens in new one) and you're in the same page you opened filemanager from :)
It should open on the same page where it was opened as the old one did. And opening on an another tab should be a configurable option.
Thers are also issues with the File edit feature:
Hello, I can't use the php settings (php.ini). I can't see that part in the theme. Are there any requirements for using this feature? centos version as an example? cloudlinux setup? or php fastcgi or modphp?
skin: evolution
edit:
When I write php settings in the search section, I can enter the php settings but it does not appear as an icon
skin: evolution
edit:
It's most likely you have a custom menu under Customize Evolution Theme.
