my Phpmyadmin didn't work
hamid.yzp
Hello every body,
After installation directadmin my phpmyadmin didn't work and I faced with this page
Service Unavailable​
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
How can i solve this problem?
there is error log for it somhwere at /var/www/html/ or one level deeper in phpMyAdmin folderthere I woult check that first
DIRECTADMIN error log:
Sun Oct 11 10:09:01.648150 2020] [ssl:warn] [pid 27938:tid 140533770707776] AH01909: www.citymon.ir:443:0 server certificate does NOT include an ID which matches the server name
[Sun Oct 11 10:10:01.770153 2020] [ssl:warn] [pid 27938:tid 140533770707776] AH01909: www.citymon.ir:443:0 server certificate does NOT include an ID which matches the server name
[Sun Oct 11 10:17:54.824233 2020] [ssl:warn] [pid 6544:tid 140413292045120] AH01909: www.citymon.ir:443:0 server certificate does NOT include an ID which matches the server name
[Sun Oct 11 10:17:54.871865 2020] [ssl:warn] [pid 6544:tid 140413292045120] AH01909: www.citymon.ir:443:0 server certificate does NOT include an ID which matches the server name
[Sun Oct 11 10:18:01.980763 2020] [ssl:warn] [pid 6544:tid 140413292045120] AH01909: www.citymon.ir:443:0 server certificate does NOT include an ID which matches the server name
[Sun Oct 11 10:51:52.525587 2020] [ssl:warn] [pid 13795:tid 140179708490560] AH01909: www.citymon.ir:443:0 server certificate does NOT include an ID which matches the server name
[Sun Oct 11 10:51:52.571520 2020] [ssl:warn] [pid 13795:tid 140179708490560] AH01909: www.citymon.ir:443:0 server certificate does NOT include an ID which matches the server name
[Sun Oct 11 10:52:01.632378 2020] [ssl:warn] [pid 13795:tid 140179708490560] AH01909: www.citymon.ir:443:0 server certificate does NOT include an ID which matches the server name
[Sun Oct 11 11:21:43.575166 2020] [ssl:warn] [pid 18278:tid 140459751551808] AH01909: www.citymon.ir:443:0 server certificate does NOT include an ID which matches the server name
[Sun Oct 11 11:21:43.624763 2020] [ssl:warn] [pid 18278:tid 140459751551808] AH01909: www.citymon.ir:443:0 server certificate does NOT include an ID which matches the server name
[Sun Oct 11 13:06:30.263345 2020] [ssl:warn] [pid 742:tid 139664769844032] AH01909: www.citymon.ir:443:0 server certificate does NOT include an ID which matches the server name
[Sun Oct 11 13:06:30.381778 2020] [ssl:warn] [pid 742:tid 139664769844032] AH01909: www.citymon.ir:443:0 server certificate does NOT include an ID which matches the server name
[Sun Oct 11 17:08:07.903058 2020] [ssl:warn] [pid 10442:tid 140135763088192] AH01909: www.citymon.ir:443:0 server certificate does NOT include an ID which matches the server name
and in /var/log/httpd/error_log
proxy_fcgi error pid 18284 tid 1404588103861761 client 5.126.151.114:0 ah01079 faild to make conection to backend httpd-uds referer http:??a85.239.107.180
Thank you for your advice
I used your code...but it seems some other error.
you can see errors in picture...
The answer there seems to suggest upgrading php. Are you saying you upgraded php so that you could upgrade php? What am I missing?
Nothing at all, with your advice I emptied my swap memory and every thing work fine.
Thanks a lot
