Date format corrupt in translation file:
urgido
Hi
On file manager awarning message appears:
Date format corrupt in translation file: "date:format" should be valid Unicode date format string, for example "yyyy-MM-dd"
VIEW
How I can solve this?
Regards
Screenshot
Everything is said in the error message. Open your translation file and fix "date:format" there to have a real date-format instead of "format" :) "format" isn't a valid date-format. Even example is provided in the message.
I have the same problem, and I must be dum or something but I can't find this translation file. Can you point me to it? thank you in advance
Hi.
I had the same issue. I fixed it by editing the .po and .json translation files, in my case es.po and es.json.
You have to find "format:date" and change it to the date format like "yyyy-MM-dd".
The translation files are in the skin folder (Enhanced or Evolution), depending on the one you are using:
/usr/local/directadmin/data/skins/enhanced/lang
/usr/local/directadmin/data/skins/evolution/lang
Regards.
I have similar issue . I got following lines
# Date format
msgid "format:date"
msgstr "formato: fecha"
Which one I should change ?
