northtones
 - May 2, 2013
For some reason named isn't starting for me. Get the error /usr/bin/systemctl start named.service 2>&1
● named.service - Berkeley Internet Name Domain (DNS)
Loaded: loaded (/etc/systemd/system/named.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sat 2020-10-17 08:23:06 CDT; 11s ago
Process: 14989 ExecStartPre=/bin/bash -c if [ ! "$DISABLE_ZONE_CHECKING" == "yes" ]; then /usr/sbin/named-checkconf -z "$NAMEDCONF"; else echo "Checking of zone file>
Oct 17 08:23:06 e2.foo.com bash[14989]: dns_rdata_fromtext: /var/named/e2.foo.com.db:30: near 'e2.foo.com': bad dotted quad
Oct 17 08:23:06 e2.foo.com bash[14989]: zone e2.foo.com/IN: loading from master file /var/named/e2.foo.com.db failed: bad dotted quad
Oct 17 08:23:06 e2.foo.com bash[14989]: zone e2.foo.com/IN: not loaded due to errors.
Oct 17 08:23:06 e2.foo.com bash[14989]: _default/e2.foo.com/IN: bad dotted quad
Oct 17 08:23:06 e2.foo.com bash[14989]: zone sitea.com/IN: loaded serial 2020092601
Oct 17 08:23:06 e2.foo.com bash[14989]: zone siteb.com/IN: loaded serial 2020092601
Oct 17 08:23:06 e2.foo.com bash[14989]: zone sitec.us/IN: loaded serial 2020092603
Oct 17 08:23:06 e2.foo.com systemd[1]: named.service: Control process exited, code=exited status=1
Oct 17 08:23:06 e2.foo.com systemd[1]: named.service: Failed with result 'exit-code'.
Oct 17 08:23:06 e2.foo.com systemd[1]: Failed to start Berkeley Internet Name Domain (DNS).
Zone file is the following.
$TTL 3600
@ IN SOA ns1.11.22.33. hostmaster.e2.foo.com. (
2020092100
3600
3600
1209600
86400 )
e2.foo.com. 3600 IN NS ns1.11.22.33.
e2.foo.com. 3600 IN NS ns2.11.22.33.
e2.foo.com. 3600 IN A e2.foo.com
ftp 3600 IN A e2.foo.com
mail 3600 IN A e2.foo.com
pop 3600 IN A e2.foo.com
smtp 3600 IN A e2.foo.com
www 3600 IN A e2.foo.com
e2.foo.com. 3600 IN MX 10 mail
e2.foo.com. 3600 IN TXT "v=spf1 a mx ip4:e2.foo.com ~all"
Any help would be appreciated.
$TTL 3600
2020092100
3600
3600
1209600
86400 )
