Error during Backup Creation
Details
/usr/local/bin/curl returned error code 67
curl: (67) Access denied: 504
FTP information invalid./usr/local/bin/curl returned error code 67 curl: (67) Access denied: 504 FTP information invalid.
Used ftps.After downgrade it worked instant, same on three other servers. Not sure if curl is the problem, but there must be a link.
Hmm our server are configured for SFTP maybe that is the catch.Used ftps.
CURLE_LOGIN_DENIED (67)
The remote server denied curl to login (Added in 7.13.1)After updating Curl to the latest version, DA back-up stopped working and gives the following error:
Code:Error during Backup Creation Details /usr/local/bin/curl returned error code 67 curl: (67) Access denied: 504 FTP information invalid.
Downgrading to 7.72.0 is fixing the problem temporarily. Somebody a better fix?
Also using synology?Same here, for SSL only FTP servers. (with self-signed certificate)
No, it is windows with FTP serviceAlso using synology?
				 daniel.haxx.se
					daniel.haxx.se
				It means the connection was denied on the remote server whatever that is. I mean some security credentials are wrong API key, user, password, and such.When I look into the error I see the following:
Code:CURLE_LOGIN_DENIED (67) The remote server denied curl to login (Added in 7.13.1)
Perhaps it has to do with my Synology system?
I have the latest version of curl and have no issues.
curl 7.73.0 – more options
In international curling competitions, each team is given 73 minutes to complete all of its throws. Welcome to curl 7.73.0. Release presentation https://www.youtube.com/embed/ebYXC0Cr-dQ Numbers the 195th release9 changes56 days (total: 8,2XX)135 bug fixes (total: 6,462)238 commits (total...daniel.haxx.se
in latest chances it states
ftp: separate FTPS from FTP over “HTTPS proxy”
The FTP code would previously wrongly consider a HTTPS proxy to euqal *using TLS” as if it was using TLS for its control channel, which made it wrongly use commands that are reserved for TLS connections.
can this be the problem? maybe directadmins codes for ftps procedure become obsolete?
After updating it did not work anymore, after downgrading it works like before. So there must be something between DA and CURL what has been changed in the update, or in the way CURL is being implemented in the current backup script. Stand alone ftp like Filezilla are working.I have the latest version of curl and have no issues.
Maybe so info about your system or your workflow might help
can you provide your backup server ftps conf file? just to check itI have the latest version of curl and have no issues.
I don’t use the backup ftp process.can you provide your backup server ftps conf file? just to check it
thanks.
