LawsHosting
Just by looking at the site source code, you can see how much tosh there is to process.......Wordpress is usually blazing fast by itself. What usually slows it down are:
1. Crappy themes
2. Crappy plugins
1. Crappy themes
2. Crappy plugins
Then it begs the question, what will..... Well, without throwing in hundreds of more pounds.If it's a single service running on the server, then static is the way to go. But this is not going to change the things a lot.
[22-Nov-2020 21:57:36] WARNING: [pool xxx] server reached max_children setting (100), consider raising it
	PHP X-Ray provides detailed information on performance bottlenecks in web sites that use WordPress. If a site has slow plugins or slow queries, this tool helps detect them. When a web site slows down, there’s usually a problem with its content management system. Now, on servers that run CloudLinux OS+, performance problems can be identified immediately using PHP X-Ray.
					www.cloudlinux.com
				We do Ban Wordpress, on own servers yup, problem is yes custommers and they expect developers from sites mostly also to do updates and problem resolving as also they demanding from hosters.I'm not reinstalling it all and fork out extra money........ I'd rather lose the client......
Maybe I should ban Wordpress! ?
Waiting for table level lock
	Good lord that plugin is 2 years old from updates. No one should be using a plugin that was last update 2 years ago.that this plugin was the main culprit,
UH was this after mariadb / mysql update on server ?Update:
It seems that this plugin was the main culprit, it was giving
for its MySQL table..... I guess it wasn't using indexes?Code:Waiting for table level lock
But..... Funny thing is, it has not been updated for 2 years....?
I love plugins </sarcasm>
No.....UH was this after mariadb / mysql update on server ?
Creating symlink for /usr/local/php74/bin/php-config74...
Creating symlink for /usr/local/php74/bin/phpize74...
Job for php-fpm73.service failed because a timeout was exceeded.
See "systemctl status php-fpm73.service" and "journalctl -xe" for details.
Job for php-fpm74.service failed because a timeout was exceeded.
See "systemctl status php-fpm74.service" and "journalctl -xe" for details.
	 Starting The PHP FastCGI Process Manager...
systemd[1]: php-fpm73.service: Start operation timed out. Terminating.
systemd[1]: php-fpm73.service: Failed with result 'timeout'.
systemd[1]: Failed to start The PHP FastCGI Process Manager.
	The service 'php-fpm74' on server xxxxxxx.laws-hosting.co.uk is currently down
What does this show?journalctl -xe
hey hey none of that talk...I think I should go and shoot myself..
