hostingsatisi
- Dec 6, 2020
there are files installed 1 day ago, the working site is currently not allowed to access forbidden errorLooks like there is no index.html, or index.php file.
file loaded inThe homepage is, by default, the index.html, or index.php file. You'll need to check if a file like that is present, and if missing, upload it
You are showing an index file in hdfilm but not in public_html
no mod security disabledDo you have mod_security enabled? If so, check the domain error log......
Failing that, try a
alt alan sorunufloyd şunları söyledi:
Peki hangisiyle sorun yaşıyorsun? Ana alan mı yoksa alt alan mı?
The error link is attached to the sample installed siteGive us the url.
I don't understand what you are saying here.If we want to open a subdomain and set up a site in which one, they all make the same mistake, it has a lot to do.
I said he makes an error when all subdomains are opened(eril)I don't understand what you are saying here.
