CentOS 8 Stream and repos renaming
itcms
Athens
Today I tried to update to 8.3 and received the following message
A package conflict is preventing me from upgrading to 8.3.
[root@srv ~]# dnf update
Last metadata expiration check: 2:45:49 ago on Sun 13 Dec 2020 05:22:07 PM CET.
Error:
Problem: cannot install both oniguruma-6.8.2-2.el8.x86_64 and oniguruma-6.8.2-1.el8.x86_64
- package oniguruma-devel-6.8.2-1.el8.x86_64 requires oniguruma = 6.8.2-1.el8, but none of the providers can be installed
- cannot install the best update candidate for package oniguruma-6.8.2-1.el8.x86_64
- problem with installed package oniguruma-devel-6.8.2-1.el8.x86_64
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
I passed via dnf with the --nobest option
Just for your reference with Centos stream has start to change the names of the .repo files and rename them to lower case names
Any who use CENTOS 8 will face many problems soon
PowerTools has been renamed to just powertools.
Enable it again with: dnf config-manager --set-enabled powertools
Verify with: dnf repolist all
Error:
dnf update --allowerasing
Error:
I have noticed this too. Actually, now CentOS already in stream repo and it's not recommended to be used in Production. It's time to move, I think Debian would be a good choice for DirectAdmin
Well, this totally sucks. Time to convert my project server over. :(
I encountered the same in my CentOS 8.2 dev server one.
It seems DirectAdmin custombuild (build v2648) use PowerTools repository to install oniguruma-devel
yum -y install oniguruma-devel --enablerepo=PowerTools
where the CentOS 8 ones want to remove it
[root@xxxx custombuild]# yum update oniguruma oniguruma-devel --allowerasing
Last metadata expiration check: 0:11:21 ago on Sun 10 Jan 2021 06:53:46 PM HKT.
Dependencies resolved.
Package Architecture Version Repository Size
Upgrading:
oniguruma x86_64 6.8.2-2.el8 AppStream 187 k
Removing dependent packages:
oniguruma-devel x86_64 6.8.2-1.el8 @PowerTools 170 k
Transaction Summary
Upgrade 1 Package
Remove 1 Package
Total download size: 187 k
Is this ok [y/N]:
Not sure the next steps.
Please read this topic also above you can find solution i think.
Maybe DA Custombuild need to update that to?
I managed to update CL 8.2 to CL 8.3 in my testing environment by
- yum erase oniguruma-devel
- yum install oniguruma-devel --enablerepo=PowerTools ( <-- same command inside custombuild build script)
it will install oniguruma-devel via PowerTools, and oniguruma via AppStream
Then, "yum update" it will update the remaining, reboot, it looks OK.
