CAA record prevents issuing the certificate: SERVFAIL
ErikdL
I see, there are more threads about this error: CAA record prevents issuing the certificate: SERVFAIL
The thing in my case is: Where is that CAA record? I can't find it with any of the tools on the web?
I use Centos7, DA2, Lets Encrypt SSL, each domain has its own.
# dig caa duivenblogs.nl
; <<>> DiG 9.11.4-P2-RedHat-9.11.4-26.P2.el7_9.3 <<>> caa duivenblogs.nl
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 38126
;; flags: qr rd ra ad; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;duivenblogs.nl. IN CAA
;; AUTHORITY SECTION:
duivenblogs.nl. 3600 IN SOA nszero1.axc.nl. hostmaster.duivenblogs.nl. 2021012703 10800 3600 604800 3600
;; Query time: 31 msec
;; SERVER: 93.180.70.22#53(93.180.70.22)
;; WHEN: Thu Jan 28 13:23:23 CET 2021
;; MSG SIZE rcvd: 114
Where to start if no CAA records can be found??
The domains are hosted on a VPS, s1.ewdl.nl
With ping this hostname resolves. But with DNSCHECKER no results.
The mail domain, ewdl.nl is hosted on another server.
Anyone any idea???
Thnx
Erik
Anyone any idea???
Thnx
Erik
as far as I know something related to dnssec.
Ask the registrar to remove any DS records (Seems to be a bug at your registrar, had the same issue there ;) )
I contacted them. Have no service contract so they can't help me..
Results of: DNSSEC Analyzer - duivenblogs.nl (verisignlabs.com) :
No problems found?? I Guess?
I got no idea how? I can add/change DNS records in my User panel on the website of my hosting provider.
In DirectAdmin there is no option to en-/disable DNSSEC or Key.
I can't find any option to disable DNSSEC.
Is lego and latest letsencrypt installed?
./build set_fastest
./build letsencrypt
./build lego
./build set_fastest
./build letsencrypt
./build lego
Just did to be sure, doesn't make a difference :S
