Solved FYI: Missing dot in tlsa.sh
sysdev
In the tlsa.sh script a dot is missing in the generation of the _25._tcp.mail.domain.com record in the "." check at line 168
HOST_TLSA="_25._tcp.${DOMAIN}"
should be
HOST_TLSA="_25._tcp.${DOMAIN}."
should be
I don't see it there. It might be an old (already fixed) bug. Are you running pre-release? I see modify date of "2020-10-03 02:17:53" (this is after latest stable).
Nope, no prerelease. Fully up2date afaik. It say's version 0.2.
Date is: Sep 27 10:26 tlsa.sh.
But on another server I have a slightly different date: 'Sep 29 23:06'
So, it might have been fixed between those dates. But now I wonder why the first never got updated...
Mine also say version 0.2 but I do have the dot present.
On both Centos 7 servers the date is Sep 27. On the Centos 8 server it's september 29th.
I always update servers the same night.
Indeed odd that your first did not get updated.
Are you using a good download server in options.conf.
Try
./build set_fastest
Alto to the 3rd party mirrors are not used anymore.
Yups, I did.
But today I get a message 'All TLSA RRs failed', while the records are all signed. I'm not sure why but TLSA seems to miss something.
Just noticed that at line 182 the dot is also missing. Might be fixed already.
No that one seems not fixed yet, if a trailing dot is required at the end. This is line 182 on both my Centos 7 and 8 servers.
MXREC="${MXREC}.${DOMAIN}"
