Marks Verified User Joined Jul 13, 2019 Messages 131 Feb 10, 2021 #1 I have a hundred server in production that some accounts are consuming a lot of resources. I would like to convert to CloudLinux. Is the process safe? Do you have an article / tutorial for me to perform the procedure?
k1l0b1t Verified User Joined May 10, 2020 Messages 483 Location Belgium Feb 10, 2021 #2 The process is perfectly fine. I've done it twice now and worked out perfect in both ocasions. If you are on a vps, make a snapshot though, or backup if you are running on a dedi/can't make snapshots, better safe than sorry
P pmjcreations Verified User Joined Jul 3, 2019 Messages 112 Feb 10, 2021 #3 It is perfectly safe, and CloudLinux converter tools will take care of things. Yeah, make sure you take snapshot/backup for a worry-free switching.
D Dutch Verified User Joined Apr 11, 2017 Messages 15 Feb 26, 2021 #4 Is a Reboot needed when you convert from CentOS to cloudlinux. ???
A alwaysbusy Verified User Joined Apr 19, 2020 Messages 108 Mar 14, 2021 #6 Thanks for the infos. Will have to switch 2 of my servers end of this year to Almalinux. Hope that goes well ;-)
S sysdev Verified User Joined Jul 16, 2007 Messages 551 Mar 14, 2021 #7 pmjcreations said: A reboot isn't needed. Click to expand... Yes, you DO need a reboot after converting to cloudlinux because you get another kernel and they say so themselves. Besides that I've had a converted centos 7 vm not booting with a cloudlinux kernel on xenserver 6.5 once.
P pmjcreations Verified User Joined Jul 3, 2019 Messages 112 Mar 14, 2021 #8 Ah, my bad. Yes, the Reboot is needed.
