Solved An error occurred during the backup
bibiugly
Vietnam
Sorry to bother you guys.
I use multiple DirectAdmin servers. But this is my first time getting this error. Today I got an error when I tried to add a user backup.
Here is the message I received:
Unable to lock the 'vuzotq' account actions:
User's System Quotas set
Error locking the User 'vuzotq' actions lock file due to existing lock created on Mar 30 02:45:01 2021. Some other process may be doing work on this account.
Have I found the following error:
[root@hv10 admin_backups]# tailf /var/log/directadmin/errortaskq.log
2021:03:30-02:50:02: User::lock_actions: Error locking the User 'vuzotq' actions lock file due to existing lock created on Mar 30 02:45:01 2021.
2021:03:30-02:50:02: Current location: License::read() : User('vuzotq')::readFile() : finished
2021:03:30-02:55:02: User::lock_actions: Error locking the User 'vuzotq' actions lock file due to existing lock created on Mar 30 02:45:01 2021.
2021:03:30-02:55:02: Current location: License::read() : User('vuzotq')::readFile() : finished
2021:03:30-03:09:02: User::lock_actions: Error locking the User 'vuzotq' actions lock file due to existing lock created on Mar 30 02:45:01 2021.
2021:03:30-03:09:02: Current location: User::setQuota(0) : vuzotq : User('vuzotq')::readFile() : finished
Hope you can help me, I am in desperation right now.
Sorry my english is too bad. I use Google translate.
Is the user over quota? The backup wont run if the users quota is full or within a certain %. I think the default is 90%
Thank you for replying to this article.
The user's quota is still there, and I backed up with the administrator account and got the error.
[root@hv10 ~]# df -h
Filesystem      Size  Used Avail Use% Mounted on
devtmpfs         63G     0   63G   0% /dev
tmpfs            63G  5.6M   63G   1% /dev/shm
tmpfs            63G  242M   63G   1% /run
tmpfs            63G     0   63G   0% /sys/fs/cgroup
/dev/sda3       2.2T  537G  1.5T  26% /
/dev/sda2       976M  168M  742M  19% /boot
/dev/sda1      1022M   12M 1011M   2% /boot/efi
tmpfs            13G     0   13G   0% /run/user/0
[root@hv10 ~]#
Do you still suggest any other solution.
Maybe this can help
Maybe this can help
I check the file task.queue.da.tmp and see the following content, should I empty this file and try backing up again?
[root@hv10 data]# cat task.queue.da.tmp
action=backup&id=1&owner=admin
[root@hv10 data]#
Try this:
The fix is to simply delete the file user.action.lock in /usr/local/directadmin/data/users/<user> folder.
rm -f /usr/local/directadmin/data/users/<user>/user.action.lock
Where <user> is the user account you want to backup.
Try backing-up again.
Ref: https://linu.tech/tech/web/server-h...ror-unable-to-lock-the-admin-account-actions/
I tried, but in /home/admin/admin_backups still create a directory containing user settings and database, there is no source.
I think I should wait about 30 minutes as the instructions you provided, and try again later.
Try this:
I just combined your tutorial and the following tutorial, everything should be working fine:
