Exim vulnerability release
CrazyFrog
Hey everybody,
I saw that Exim has a new security release which looks important:
Exim 4.94.2 - security update released
Dear Exim-Users
Abstract
Several exploitable vulnerabilities in Exim were reported to us and are
fixed.
We have prepared a security release, tagged as "exim-4.94.2".
This release contains all changes on the exim-4.94+fixes branch plus
security fixes.
You should update your Exim instances as soon as possible. (See below
for short upgrade notes.)
For further reference a list of related CVEs:
Local vulnerabilities
- CVE-2020-28007: Link attack in Exim's log directory
- CVE-2020-28008: Assorted attacks in Exim's spool directory
- CVE-2020-28014: Arbitrary PID file creation
- CVE-2020-28011: Heap buffer overflow in queue_run()
- CVE-2020-28010: Heap out-of-bounds write in main()
- CVE-2020-28013: Heap buffer overflow in parse_fix_phrase()
- CVE-2020-28016: Heap out-of-bounds write in parse_fix_phrase()
- CVE-2020-28015: New-line injection into spool header file (local)
- CVE-2020-28012: Missing close-on-exec flag for privileged pipe
- CVE-2020-28009: Integer overflow in get_stdinput()
Remote vulnerabilities
- CVE-2020-28017: Integer overflow in receive_add_recipient()
- CVE-2020-28020: Integer overflow in receive_msg()
- CVE-2020-28023: Out-of-bounds read in smtp_setup_msg()
- CVE-2020-28021: New-line injection into spool header file (remote)
- CVE-2020-28022: Heap out-of-bounds read and write in extract_option()
- CVE-2020-28026: Line truncation and injection in spool_read_header()
- CVE-2020-28019: Failure to reset function pointer after BDAT error
- CVE-2020-28024: Heap buffer underflow in smtp_ungetc()
- CVE-2020-28018: Use-after-free in tls-openssl.c
- CVE-2020-28025: Heap out-of-bounds read in pdkim_finish_bodyhash()
I saw that it is not yet in CustomBuild.
/usr/local/directadmin/custombuild/build update
/usr/local/directadmin/custombuild/build versions | grep Exim
Latest version of Exim: 4.94
Installed version of Exim: 4.94
Could the Exim version be bumped in CustomBuild?
Thanks in advance!
CF
It seems versions.txt is not updated.
Yes, as it seems to have some issues with the taints, still checking before changing versions.txt. It'll likely require exim.conf update :)
Oooh, that’s too bad. Apps requiring changes on a security release ? Good luck with the testing and will be anxiously checking the result :)
Great, I've updated my machines and all is looking well ?
For those who need the commands:
sudo /usr/local/directadmin/custombuild/build update
sudo /usr/local/directadmin/custombuild/build versions | grep Exim # should show Exim 4.92.2 available
sudo /usr/local/directadmin/custombuild/build exim
sudo /usr/local/directadmin/custombuild/build exim_conf
I've got an issue with exim after recent update. I'm using an official mirror.
./build exim
./build exim_conf
Afterward I get the following error:
failed to expand "${if exists{/etc/virtual/${domain}/aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/aliases}}}}
I've got this issue on multiple servers.
./build exim
./build exim_conf
What version of exim.conf are you using?
The issue was related to the eximconf_release switch not being automatically updated to a new version. It was stuck at 4.3 instead of 4.5. Although that exim and exim_conf are both set to yes in the options.conf
Hi
For over 2 days i'm getting some type of attack every second 2 - 5 connections from diffrent IP's. No password and username only connection.
Unexpected disconnection while reading SMTP command from
Does anyone else have this problem?
I updated to the last version but i have the same problem. I hoped the update would fix the problem
Installed version of Exim: 4.94.2
Installed version of exim.conf: 4.5.35
./build exim
./build exim_conf
I think you may have updated just the versions.txt and not the custombuild script?
See post #16:
Detailed blog post:
Some of the vulnerabilities can be chained together to obtain a full remote unauthenticated code execution and gain root privileges on the Exim Server. Most of the vulnerabilities discovered by the Qualys Research Team for e.g. CVE-2020-28017 affects all versions of Exim going back all the way to 2004 (going back to the beginning of its Git history 17 years ago).
