CrazyFrog
- Aug 28, 2019
Hey everybody,
I saw that Exim has a new security release which looks important:
I saw that it is not yet in CustomBuild.
Could the Exim version be bumped in CustomBuild?
Thanks in advance!
CF
Exim 4.94.2 - security update released
Dear Exim-Users
Abstract
Several exploitable vulnerabilities in Exim were reported to us and are
fixed.
We have prepared a security release, tagged as "exim-4.94.2".
This release contains all changes on the exim-4.94+fixes branch plus
security fixes.
You should update your Exim instances as soon as possible. (See below
for short upgrade notes.)
For further reference a list of related CVEs:
Local vulnerabilities
- CVE-2020-28007: Link attack in Exim's log directory
- CVE-2020-28008: Assorted attacks in Exim's spool directory
- CVE-2020-28014: Arbitrary PID file creation
- CVE-2020-28011: Heap buffer overflow in queue_run()
- CVE-2020-28010: Heap out-of-bounds write in main()
- CVE-2020-28013: Heap buffer overflow in parse_fix_phrase()
- CVE-2020-28016: Heap out-of-bounds write in parse_fix_phrase()
- CVE-2020-28015: New-line injection into spool header file (local)
- CVE-2020-28012: Missing close-on-exec flag for privileged pipe
- CVE-2020-28009: Integer overflow in get_stdinput()
Remote vulnerabilities
- CVE-2020-28017: Integer overflow in receive_add_recipient()
- CVE-2020-28020: Integer overflow in receive_msg()
- CVE-2020-28023: Out-of-bounds read in smtp_setup_msg()
- CVE-2020-28021: New-line injection into spool header file (remote)
- CVE-2020-28022: Heap out-of-bounds read and write in extract_option()
- CVE-2020-28026: Line truncation and injection in spool_read_header()
- CVE-2020-28019: Failure to reset function pointer after BDAT error
- CVE-2020-28024: Heap buffer underflow in smtp_ungetc()
- CVE-2020-28018: Use-after-free in tls-openssl.c
- CVE-2020-28025: Heap out-of-bounds read in pdkim_finish_bodyhash()
/usr/local/directadmin/custombuild/build update
/usr/local/directadmin/custombuild/build versions | grep Exim
Latest version of Exim: 4.94
Installed version of Exim: 4.94
Thanks in advance!
CF
