DA Migration Tool plugin
buHost
I leave here a plugin that may be useful. I hope it is useful.
DA Migration Tool is a completely free plug-in for DirectAdmin that greatly facilitates mass migration of accounts from remote servers with DirectAdmin or WHM/cPanel control panels, with automated functions that allow for unattended task and less overall time window on delegation change.
Features and instructions here:
It's good.
I want to try it
I hope DA can create this feature soon.
Impressive!!!
This is a must to have tool to any hoster!
I'm using bu-backup and with this all will be more easy!
Un saludo desde Chile hacia Argentina por este excelente aporte!
I trying to install but after install when I access plugins its only blank show
If the default PHP version is 8.x, or if IonCube is missing in the default version it may not work.
Errors are saved in /usr/local/busoft/da-migration-tool/log/error_log
Fixed a bug with PHP 7.1. Please update the plugin and let me know if it was fixed.
Thank you, I already update and now is working.
Nice plugins makes it easier to migrate between directadmins which has been very inconvenient
I try in another server can't retrieve the account list and it takes too long to load, but on the first server I installed yesterday it worked fine, I can't see where the error is because there is no error message. just like this https://prnt.sc/1azdk7j but on first server I install this plugins is working to access same server https://prnt.sc/1azdzz4
Just tested it migrate 20 accounts from cPanel - works ok but have some issues
Changing remote DNS zone IP Domain:
do NOT change A records on both domain and subdomains (i think it added new IP in SPF :) )
I use cPanel 94 LTS and cPanel dns cluster
Im having the same issue when testing the plugin.
Is this still available or does anyone have a copy of the archive? The download on the site is showing a 403 currently.
You only can download directly from a directadmin install using the plugin section in directadmin.
