Email Level Plugin
Let me check this.
Seems I found the issue, new tar.gz file has email_level folder inside the tar so it doesn't find the path. (Installing it will fail as well):
# cd email_level/
# ls
available_version.txt email_level plugin.conf plugin.tar.gz
Hello, i just installed this plugin version 2.0.2. Afters installing, i do get login screen but not able to login. Just get "Please enter valid password"
On debian 10, php 7.3, all software up to date.
https://server.domain.com:2222/CMD_CHANGE_EMAIL_PASSWORD this works
Some of the original DA code is filtering characters from the password input based on a regex expression. I wonder if your password has a character that is excluded in the regex expression?
I've never tested on Debian, but wouldn't expect it to stop working in any other case.
I have just tried this plugin and found that at the login page it always return
"You have entered and invalid email or password"​
I tried creating new email and try logging in with that new one without success. (Tried both full email address and only inbox name without @domain. Nothing works!)
In Web Error Log, there are only PHP Notice like these;
PHP Notice:  Undefined index: user in /home/username/domains/my-domain/public_html/email/include/httpsocket.php on line 145
PHP Notice:  Undefined index: pass in /home/username/domains/my-domain/public_html/email/include/httpsocket.php on line 145
PHP Notice:  Undefined index: query in /home/username/domains/my-domain/public_html/email/include/httpsocket.php on line 148
PHP Notice:  Undefined index: error in /home/username/domains/my-domain/public_html/email/login.php on line 92
PHP Notice:  Undefined index: text in /home/username/domains/my-domain/public_html/email/login.php on line 94', referer: https://my-domain/email/index.php
What should I do to fix this problem?
What version of DA and PHP are you running?
I am also seeing the same using DA 1.641, Simplificare Email Level 2.0.2 on Centos 7 with CloudLinux. PHP 5.6.40 (need it for legacy reason on this one server)
If I use a password with any non-alphanumeric chars in it then I cannot login. If I use a simple alphanumeric password then it works fine.
RoundCube login works for both.
My DA has just been updated to 1.641 on Jun 9 (3 weeks ago).
I have just updated main PHP from 5.6.x to 7.4.x a few weeks ago (after my comment above).
All mail addresses and password is simple alphanumeric characters.
The result is exactly the same as I said above.
Thanks.
Sorry guys, I don't have time to work on the plugin at the moment. Feel free to fork the repository or edit the code yourself to troubleshoot/resolve your issues.
Here you can find a quickly patched version of the plugin https://github.com/poralix/email_level which is made to work under PHP 8.x. No other issues are addressed. Original design and so on.
To install the plugin run the following commands:
Bash:
cd /usr/local/directadmin/plugins
git clone https://github.com/poralix/email_level.git
cd email_level
./scripts/install.sh
The installation script will overwrite data/include/config.php with a servername and port taken from Directadmin.
