ChiefZigZag
 - Feb 17, 2020
Hi, I am wondering if the version of MariaDB 10.3.31 included in the custombuild has the bug posted on the website concerning FreeBSD. I have had some problems with it recently, It is continually crashing.
If so, the recommended fix seems to suggest using the version from FreeBSD ports instead. Any suggestions on how I should handle this?
				Warning: This version can cause InnoDB file corruption on FreeBSD and on AIX. If you are using AIX, please, stick to an earlier release, or upgrade to a more recent release. If you are using FreeBSD, upgrade to the bugfix release (the version ends with _1) of the mariadb-server from the Ports Collection. See MDEV-26537.
