phpmyadmin login, disable login to db via basic auth, is is possible?
msok20
Is it possible to enable a way of logging into the database but through phpmyadmin? I can only log in via BASIC AUTH. I
Is it possible to disable this option and enable phpmyadmin login?
Regards,
Yes this is okey,
but how to secure panel login with basic auth password?
Yes this is okey,
Trying to understand your aim. So you are trying to use one-click login, and when it gets redirect to PHPMyAdmin and you would ask for another layer of password using htpasswd? When you say 'panel login' do you mean directadmin panel or phpymyadmin panel?
