Rebuild reseller's user.list difficulties
d_noizeshakerz
Hi all,
I tried running the following bash taken from https://docs.directadmin.com/direct...how-to-rebuild-all-resellers-users-list-files
But getting the following error. May someone shed some light on why this is the case?
fix.sh: command substitution: line 5: unexpected EOF while looking for matching `"'
fix.sh: command substitution: line 6: syntax error: unexpected end of file
The code:
#!/bin/sh
cd /usr/local/directadmin/data/users
for r in `ls */reseller.conf | cut -d/ -f1`; do
     echo "fixing Reseller $r ...";
     echo -n '' > $r/users.list
     for u in `grep "^creator=$rquot; */user.conf | cut -d/ -f1`; do
         ISUSER=`grep -c usertype=user $u/user.conf`
         if [ "$ISUSER" = "1" ]; then
             echo $u >> $r/users.list
         fi
     done;
done;
Are you sure you've copied all the code there? It may be incomplete.
Hi Smtalk,
Thanks for responding! Yes, I did. Multiple times in fact, and verified it more than one time.
I've copied the code from this thread and it works for rebuilding the corrupted reseller's lists file:
Clearly, there are differences in the code. I.e line 11. You may want to update the code snippet in the DA docs
