Error : Your DirectAdmin version is older than minimal required ...
rezapj
custom build error when i try any build command
Your DirectAdmin version (1.61) is older than minimal required for this version of CustomBuild (1.63). Please run '/usr/local/directadmin/custombuild/build update_da'
and After try /usr/local/directadmin/custombuild/build update_da . nothing happen ... nothing .
just type updating directadmin and backed to commandline
i try update from CustomBuild section but its same OS nothing happen
and in license section . After 1h of this mssg "Your request for an update will begin in under a minute. You should be notified via the Message system when it is complete" nothing changed :D
Try to update with CLI as admin.
./build update_da
./build update_da
nothing happen and back to command line
with some try i receive this massage
This is an automated message notifying you that an error has occurred while trying to update the software.
The generated error message is as follows:
Unable to connect to 167.172.23.237
Unable to connect to secure socket: Some I/O error occurred. The OpenSSL error queue may contain more information on the error. If the error queue is empty (i.e. ERR_get_error() returns 0), ret can be used to find out more about the error: If ret == 0, an EOF was observed that violates the protocol. If ret == -1, the underlying BIO reported an I/O error (for socket I/O on Unix systems, consult errno for details).
Unable to connect to 216.144.255.179
Unable to connect to 192.169.82.155
Unable to connect to 66.51.122.131
Unable to connect to 69.162.69.58
Unable to connect to any site for the update
Please contact JBMC-Software, including the error message. Failure to do so could result in an inactive control panel.
try ping all ip's in mssg from OS .and all pinged
try this page https://docs.directadmin.com/getting-started/installation/ip-requirements.html timeout test and everything was ok .downloaded files
Hmm, it actually depends on directadmin version that the server runs.
I had different errors with the manual update as the syntax was slightly different.
For example, the old version of it required manual CID and LID to be entered:
# /usr/local/directadmin/scripts/getDA.sh
Usage:
/usr/local/directadmin/scripts/getDA.sh <cid> <lid> [<ip>]
definitons:
  cid: Client ID
  lid: License ID
  ip:  your server IP (only needed when wrong ip is used to get the update.tar.gz file)
example: /usr/local/directadmin/scripts/getDA.sh 999 9876
Or a little newer version had "auto" part in there:
Usage:
    This will get the 'currrent' channel
    /usr/local/directadmin/scripts/getDA.sh auto
or:
    /usr/local/directadmin/scripts/getDA.sh auto alpha
    /usr/local/directadmin/scripts/getDA.sh auto beta
    /usr/local/directadmin/scripts/getDA.sh auto current
    /usr/local/directadmin/scripts/getDA.sh auto stable
or:
definitons:
  cid: Client ID
  lid: License ID
So the bullet proof way would be to execute the getDA.sh without arguments first to see what it expects.
Usage:
definitons:
  cid: Client ID
  lid: License ID
Usage:
or:
or:
definitons:
  cid: Client ID
  lid: License ID
i use CID LID but get error
"" Error downloading the update.tar.gz file ""
i think my server cannot connect directadmin servers ( i must check it ) and dont know how
I've sent you personal instruction. Please check if it works.
We are running into the same problem when upgrading older Ubuntu systems. Before we always updated DirectAdmin manually after an OS release upgrade but this now refuses to download. The new DirectAdmin update script method also refuses to download.
Old method:
cd /usr/local/directadmin
wget --no-check-certificate -O update.tar.gz 'https://update.directadmin.com/cgi-bin/daupdate?redirect=ok&uid=<REDACTED>&lid=<REDACTED>'
tar xvzf update.tar.gz
./directadmin p
cd scripts
./update.sh
service directadmin restart
Could you please provide us with instructions on how to update DirectAdmin manually so we can upgrade EOL systems?
UPDATE:
We got it working again, before we tried to specify the update channel, for example;
/usr/local/directadmin/scripts/getDA.sh stable <UID> <LID>
But this gave us an forbidden error, now with just giving the UID & LID the .tar.gz download works and I'm able to manually upgrade DirectAdmin with the old method. We will need to do a bit of extra testing to see how this impacts future Ubuntu upgrades but it seems to be working fine.
--2021-12-30 19:07:39-- https://www.directadmin.com/cgi-bin/daupdate?lid=5491&uid=stable
Resolving www.directadmin.com (www.directadmin.com)... 167.172.23.237
Connecting to www.directadmin.com (www.directadmin.com)|167.172.23.237|:443... connected.
HTTP request sent, awaiting response...
HTTP/1.1 400 Bad request
Server: nginx
Date: Thu, 30 Dec 2021 18:07:40 GMT
Content-Type: text/html
Content-Length: 46
Connection: keep-alive
x-return-code: error
x-error-code: 20
Vary: User-Agent
2021-12-30 19:07:39 ERROR 400: Bad request.
root@webserver:~#
