- Feb 27, 2003
This post is intended to help our datacenter partners adjust to our new, more powerful, key-based licensing system.
This new licensing system will offer more flexible options for datacenters, and less confusion for their end-users. No longer will there be reliance on the old method of Client ID / User ID / License IP / License OS. Intelligent keys have finally arrived.
Datacenters will save time through effortless license provisioning. No information about the server is required to generate a key. In fact, datacenters can offer keys as a standalone product! Your customer can then float the key between any servers they rent from you, and it will "just work."
Current Status
Our new key-based system is already functioning under the hood as our primary licensing engine. Once we complete further optimizations and GUI (client account) features, we will officially announce the switch to key-based licensing. There will be plenty of notice given, including notifications in the client account, when this system is ready. Then, plenty of time will be given for datacenters to make adjustments (update their scripting/automation, if needed).
IMPORTANT: Our licensing system is now operating in a hybrid mode (new & old licensing methods) to make the transition as easy and seamless as possible. This becomes impossible if your customers are running outdated DirectAdmin versions. Please see this thread.
Where to Find the Key Hash
Login to your account and click on a license to view it. You will see a "License Key" row, with the key next to it. If the license has been long idle, or running an older DA version, it is possible no key exists yet. Click on the (+) symbol and look for the reset key link.
Getting the key and resetting the key can also be done through our licensing API (see below).
Creating Keys That Require No Customer or Server information (STANDALONE KEYS)
If you are ordering keys (licenses) through our web portal, you will see some changes on the order form. Now, the IP address and Operating System fields default to "Auto-detect" -- and the key will work for your customer, anywhere in your IP space. You can restrict this usage further, if required (see next section).
Please note: If you use this method, you must provide your customer the license key hash, as the installer will prompt for it.
Standalone keys can also be created through our licensing API (see below).
Key Security
A license key is secure, unless it is leaked or stolen. The license key hash should be provided to your customer and treated as private information, similar to your customer's server login information.
A retail license key may be used anywhere, but datacenter keys should never be used outside of the datacenter's authorized IP space. To prevent customer misuse, we have two IP-limiting mechanisms in place. The most important is Client IP Restrictions, an area of your account where you can register the IPv4/IPv6 ranges you operate under. This is a global (account-wide) restriction that has authority over all other restrictions. Therefore, when a key is used outside of these ranges, it automatically fails.
Important: Any IP ranges you enter may be subject to verification -- this will help us prevent abuse, unauthorized resale of licenses, or encroaching on the IP space of others.
Secondly, you may further restrict key usage at the license level. When viewing a license in your account, below the license key row you will see an IP Restriction link. You can use this feature to make the license function as a legacy license (usable only on one IP). Please note, the traditional license IP (seen at the top of the screen) is ignored by keys. You must use this IP Restriction link to further limit the key.
You will also see a new option called IP Auto Lock. This will simply automate per-license IP Restrictions for you. The first detected IPv4 and/or IPv6 will be locked to the key, preventing it from being used on any other IP address(es). Certain accounts may have IP Auto Lock applied automatically, but active datacenter accounts can freely enable/disable this feature at any time.
We do not anticipate datacenters needing these secondary (per-license) measures, as it is a time-saver for you and your customers to have free-floating keys that do not require constant adjustment. Typically, just Client IP Restrictions (global settings) should be enough.
You may also set per-license IP restrictions, and enable/disable IP Auto Lock, using our licensing API (see below).
Install Methods
Always point your customers to our official install guide, as it provides the most accurate and updated information. No matter how you provision licenses (legacy system, or key-based system), this guide will work for your customer.
Legacy install methods that remain acceptable are:
or
Both these methods will allow installation without knowing the license key hash.
Please note: If you are using legacy methods, your customer's server IPv4 must be defined in the IP address field of the license, as traditionally done in the past. This is what our legacy licensing system uses to match an IP with a license.
For additional info on installer features and options, run:
License Update Methods
There is no longer a need for a customer to refresh their key. A key file does not need to be updated or refreshed on a regular basis.
For information purposes, the key file is located at:
Our traditional getLicense.sh script is now only used for the case of a key update (forcing a different key onto the server). Usage:
This will download the new key, and restart DirectAdmin.
Licensing API
If you are using our licensing API, you will notice some new entries:
Be sure to watch your account for official announcements, and this thread for interim updates.
Current Status
Key Security
Install Methods
./setup.sh auto
./setup.sh UID LID
./setup.sh --help
/usr/local/directadmin/conf/license.key
/usr/local/directadmin/scripts/getLicense.sh NewLicenseKey
Licensing API
- Under List Licenses, the ability to return the license key.
- Under Reset License Key Hash, the ability to reset the license key.
- Under License IP Restrictions, the ability to lock a license to a specific IP or range, to prevent its usability over your entire IP space.
- Under Create a License, the ability to set NULL for license IP and license OS, to create a standalone key that works over your entire IP space
- Under Change OS and Change IP, the ability to set NULL values
