Apt mariadb issue
k1l0b1t
Belgium
Hello
So, Directadmin installs mariadb/mysql directly from a package, and not using apt.
I ran an apt-update yesterday, and I noticed apt tried to update some mariadb packages:
dpkg: fout bij verwerken van pakket libmariadb3:amd64 (--configure):
vereistenproblemen - blijft ongeconfigureerd
Fouten gevonden tijdens verwerken van:
mariadb-common
libmariadb3:amd64
E: Sub-process /usr/bin/dpkg returned an error code (1)
(it's dutch, saying "error with processing package libmariadb3"; and then "errors found when processing: mariadb-common libmariadb3:amd64")
Anyone knows how I can fix this?
You should not mixing things, SQL is maintained by the Custombuild and not by apt or yum.
For updates you must use CB and not doing updates manually
yes, I do know that, except this happened during a normal upgrade, so it seems that some other package triggered this or something, and since apt has no ignore like yum does, it just tried installing that when i ran apt upgrade
libdbd-mysql-perl libmailutils7 mailutils seem to be the issue, they require those two packages
some of my code needs libdbd-mysql-perl, though I can work around that, so not a big deal
not sure what needs libmailutils7 / mailutils (I guess I'll see when things break)
I do wonder why mariadb isn't installed via apt, as it's from a .deb anyways.
I do apt update and apt upgrade all the time
You need you use
Maybe instead
They are separated now. The 2 database server have really separated last few years so you cant use some of the mysql* packages if you are using Mariadb. Think of them as seperate now.
no, that also has the same dependencies, so it'd generate the same issue. workaround is loading the data from a csv file generated by some other script, messy but I have to replace these old scripts some time soon anyways so I guess I'll just rewrite them now :D
