My server is down
You can take a new back whenever you want.
Are all the services up?
Can you login to DA?
what does this show
systemctl list-units --type=service --state=running
this
OK good the system is up in running.
If you want pm me the website domain. I can check it.
Do you see a website now?
i found this . Can be?
If you get the message:
Your IP is blacklisted
this means that you've had too many failed login attempts or accesses to port 2222 without being logged in.
To remove yourself from the blacklist, edit /usr/local/directadmin/data/admin/ip_blacklist and remove your IP from the list.
Im wrong
you forgot the t at the end. It's:
nano /usr/local/directadmin/data/admin/ip_blacklist
if you see your ip in there remove it.
You can do that with ctrl-K
After that use ctrl-x to close and y to save/overwrite.
in ssh
csf -dr "Put your ip here"
To find your IP use
