My server is down
Test what bdacus01 said.
If it still does not work and you want me to have a short look for you what's going on, you can reach me by pm.
what does this show in ssh
/usr/local/directadmin/directadmin c | grep blacklist
Also clear your browser cache
DirectAdmin on the domain you provided is reachable on my end, so it's your browser or your IP is blocked, as mentioned in the posts above. Did you try on mobile / 4G?
Deep breath, at least the site is up and running. Just need to figure out why you might be locked out. Doesn't make sense if you can ssh in unless you not using the same IP that is blacklisted.
Right, for example. When I log into my VM, I am not logging in via my home IP. When I think I am locked out, I typically go onto my mobile to check if I'm locked out or the server is actually down. (Although it's been years since I locked myself out)
