Problem with backing up accounts
asenator
Hello
Finally, when I try to back up Direct Admin accounts at the admin level, I get an error.
1 - Percent is shown as -100%
2 - DirectAdmin General Discussion
Images attached
After the backup operation, the ongoing tab appears irregularly and shows the above and is not done locally and ftp.
In the last few days, a full backup has been taken regularly on ftp. The latest backup files have been encountered and will not be recovered directly from Direct Admin.
Best Regard
thanks for reply
The values of the log files are as follows
/var/log/directadmin/errortaskq.log
2022:05:09-03:45:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:46:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:47:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:48:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:49:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:50:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:51:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:52:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:53:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:54:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:55:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:56:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:57:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:58:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-03:59:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:00:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:01:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:01:21: Unable to Update the license file!: New License is invalid: Unable to read the contents of the license<br>
<br>
Return code: no_result<br>
2022:05:09-04:02:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:03:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:04:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:05:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:06:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:07:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:08:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:09:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:10:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:11:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:12:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:13:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:14:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:15:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:16:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:17:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:18:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:19:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:20:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:21:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:22:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:23:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:24:02: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:25:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:26:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:27:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:28:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:29:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:30:01: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
/var/log/directadmin/error.log
022:05:08-04:08:35: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2022:05:08-04:08:35: Send:sendData(/): attempted to send 1648 bytes, but only 0 were delivered
2022:05:08-05:57:59: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:08-05:58:03: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:08-06:04:05: ConfigFile::writeFile: Unable to move ./data/users/admin/ticket.conf.temp to ./data/users/admin/ticket.conf : No such file or directory (errno=2)
2022:05:08-06:09:07: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:08-06:09:57: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:08-06:23:32: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2022:05:08-06:42:43: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2022:05:08-06:42:43: Error while sending file. Sent 0
2022:05:08-06:43:50: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2022:05:08-06:43:50: Error while sending file. Sent 0
2022:05:08-06:43:50: Send:sendData(/IMG_FAVICON): attempted to send 2356 bytes, but only 0 were delivered
2022:05:08-06:43:51: Socket write error: Unknown error: Connection reset by peer
2022:05:08-06:43:51: Error while sending file. Sent 45
2022:05:08-06:45:31: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2022:05:08-06:45:31: Error while sending file. Sent 0
2022:05:08-11:35:05: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:08-11:35:55: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:08-11:38:27: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2022:05:08-11:38:27: Send:sendData(/): attempted to send 1683 bytes, but only 0 were delivered
2022:05:08-12:06:10: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
2022:05:09-04:01:22: auto_detect_filesystem_type=1: quota_partition=/home and use_xfs_quota=0 : but xfs is used for /home. Setting use_xfs_quota=1, xfs_on_domains=1
Have you checked the directadmin logs to see if you find any errors there?
I don't see any error related to your problem in log, but there is something you better can fix:
But what worries me is this error:
