bluesteam
- Jan 28, 2021
I have followed the following process to move a domain from one user to another user:
www.ipserverone.info
and this one:
so my first step was to create the new user with fakedomain.com and then I ran the script with the necessary parameters from old user to the new user but I get the following message:
Obviously I replaced theolduser and thenewuser with the correct values.
So what could be wrong that I cannot move this domain between the two users?
How To Transfer a Domain From a User To Another User For DirectAdmin
If you are using the Directadmin control panel, you may use a script to transfer a domain from a user to another user. However, you will need to have SSH access to the server in order to use this method. Step 1 – The DirectAdmin installation will come with a script that transfers a
and this one:
Maintaining domains, users, resellers | DirectAdmin Docs
DirectAdmin Knowledge Base
docs.directadmin.com
[root@admin scripts]# ./move_domain.sh georgesplace.com theolduser thenewuser
the new home is blank
