Per package/plan disable statistics
jonium
Alezio - Lecce- Apulia - South Italy
we provide a free package plan for dns management only, it would be very nice to disable statistics for that because the space continuously grows and if I set a limit it is always exceedeed.
Actually DA doesn't allow to disable statistics for package (plans), anyway is it safe and correct to delete or rename the file /home/yyy/domains/xxxxx.xxx/awstats/.data/awstats.xxxxx.xxx.conf ?
The question is:
is there a list of domains to be processed stored anywhere else?
if not I think it's safe to delete those .conf files and awstats, when nightly processing stats, will proceed to the subsequent domain without errors.
I would be sure not to break the awstats process
It was discussed recently on the forums, and it can also be found in the docs.
If you want to disable awstats and webalizer, use these values in the directadmin.conf file to disable them:
awstats=0 webalizer=0 and restart directadmin.
If you do it this way, then it's server wide.
seems it doesn't work with plans.
I added
awstats=0
webalizer=0
in
/usr/local/directadmin/data/resellername/packages/plansname.pkg
Then create from the reseller a new virtual host with that plan and it doesn't have
awstats=0
webalizer=0
in the user.conf
Gretings,
Pier Paolo Ronzino
