- Aug 30, 2021
Hi everyone!
We are happy to announce the release of DirectAdmin 1.642.
Release Change log can can be found here:
Highlight of this release is cPanel import feature in GUI and Evolution customizations upgrade allowing to upload custom icons and add custom CSS code directly in the GUI.
Note: With this release we are deprecating Evolution sub-theming support. With extended Evolution customizations support it is now possible to make all the changes that was previously available with sub-themes directly in the Customizations section without the themes support. If you have been using our traditional sub-theme after this upgrade sub-theme will no longer work, but the same UI changes can be quickly done by adding this CSS customization block in the Customize Evolution Skin -> CSS Styles -> Icons Grid section:
fln
DirectAdmin 1.642
The update should be automatically available for all installations subscribed to the current release channel.Highlight of this release is cPanel import feature in GUI and Evolution customizations upgrade allowing to upload custom icons and add custom CSS code directly in the GUI.
/* Styles to for 'traditional' sub-theme */
html.layout\:grid .app .app-header {background: var(--classic);color: white;}
html.layout\:grid .app .app-header .header-logo {background-image: var(--img-logo-dark); }
html.layout\:grid .app .app-header .userbar {margin-left: 1rem;}
html.layout\:grid .app .app-header .userbar>.userbar-button>.userbar-button-text {color: white;}
html.layout\:grid .app .app-header .userbar>.userbar-button>.ui-icon-counter .roundBadge {background: var(--classic-l90);color: var(--classic);}
html.layout\:grid .app .app-header .userbar .userbar-button-caret>svg>path {fill: white !important;}
html.layout\:grid .app .app-header .nav-grid-trigger svg {color: white !important;}
html.layout\:grid .app .app-header .nav-grid-trigger svg:hover {color: white !important;opacity: 0.8;}
html.layout\:grid .app .app-header .domainsDropdown .Select>.Select__Button {border-color: var(--classic-l10);background: transparent;}
html.layout\:grid .app .app-header .domainsDropdown .Select>.Select__Button>.Select__Button__Label {color: white;}
html.layout\:grid .app .app-header .domainsDropdown .Select>.Select__Button>.Select__Button__Caret>svg {color: var(--classic-l10);}
html.layout\:grid .app .app-header .domainsDropdown .Select>.Select__Button>.Select__Button__Search {background: transparent;color: white;}
html.layout\:grid .app .app-header .domainsDropdown .Select>.Select__Button>.Select__Button__Search::placeholder {color: var(--classic-l30);}
html.layout\:grid .app .app-header .search input[type="text"] {background: transparent;color: white;border-color: var(--classic-l10);}
html.layout\:grid .app .app-header .search input[type="text"]::placeholder {color: white;opacity: 0.9;}
html.layout\:grid .app .app-header .search .search-icon>.icon>svg, html.layout\:grid .app .app-header .search .options-icon>.icon>svg {color: var(--classic-l10);}
html.layout\:grid .app .app-header .ui-toggle-switch {background: var(--classic);color: #fff;border-color: var(--classic-l10);}
html.layout\:grid .app .app-header .ui-toggle-switch>.label {background: var(--classic);color: #fff;}
html.layout\:grid .app .app-header .ui-toggle-switch>.options>.slider {background: var(--classic-l30);}
html.layout\:grid .app .icons-grid .filters-bar>.filters-bar-search {flex-grow: 1;margin-right: 1rem;}
html.layout\:grid .app .icons-grid .icons-grid-category {border: 1px solid #e5e5e5;border-radius: 4px;}
html.layout\:grid .app .icons-grid .icons-grid-category .icons-grid-category-title {padding: 1rem 1rem;background-color: var(--classic);border-top-left-radius: 4px;border-top-right-radius: 4px;color: white;}
html.layout\:grid .app .icons-grid .icons-grid-category .icons-grid-category-entries .icons-grid-category-entry {border-width: 0;}
html.layout\:grid .app .dashboard-mobile>div {padding: 1.5rem;padding-left: 1rem;}
html.layout\:grid .app .dashboard-mobile>div section.dashboardTab.dashboardTab {padding: 0 !important;}
html.layout\:grid .app .dashboard-mobile>div section.dashboardTab.dashboardTab .dashboardTabHeader {padding: 1rem 1rem;font-size: 1.3rem;font-weight: 600;letter-spacing: 0.5px;}
html.layout\:grid .app .dashboard-mobile>div section.dashboardTab.dashboardTab .dashboardTabHeader .icon svg {width: 16px !important;height: 16px !important;}
html.layout\:grid .app .dashboard-mobile>div section.dashboardTab.dashboardTab.-is-active {border: 1px solid #e5e5e5;border-radius: 4px;}
html.layout\:grid .app .dashboard-mobile>div section.dashboardTab.dashboardTab.-is-active .dashboardTabHeader {background: var(--classic);color: white;}
html.layout\:grid .app .dashboard-mobile>div section.dashboardTab.dashboardTab p.type\:h6 {padding: 0 1rem;}
html.layout\:grid .app .dashboard-mobile>div section.dashboardTab.dashboardTab .dashboardTab-more {margin-left: 1rem;}
html.layout\:grid .app .dashboard-mobile>div section.dashboardTab.dashboardTab .widget-content {padding: 1rem;}
fln
