paisley
 - Aug 17, 2013
tried to install direct login with Roundcube, but looks the tar file is corrupt or does not exist.
But the file is there:
Things I tried:
- clean up old install files
- remove the tar.gz file & build update
- change to other directadmin custom repo
Hope someone can help me out..
[root@server custombuild]# ./build roundcube
Found MySQL version 10.3
Granting access: GRANT SELECT,INSERT,UPDATE,DELETE,CREATE,DROP,ALTER,LOCK TABLES,INDEX,REFERENCES ON da_roundcube.* TO 'da_roundcube'@'localhost';
Setting password: ALTER USER 'da_roundcube'@'localhost' IDENTIFIED BY '****';
Editing roundcube configuration...
########################################################################################################## 100.0%
tar (child): roundcube_direct_login-0.8.tar.gz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
chown: cannot access 'direct_login': No such file or directory
chmod: cannot access 'direct_login': No such file or directory
chmod: cannot access 'direct_login/tokens': No such file or directory
chmod: cannot access 'direct_login/index.php': No such file or directory
Roundcube 1.6.0 has been installed successfully.
-rw------- 1 root root 2282 Aug 19 17:47 roundcube_direct_login-0.8.tar.gz
-rw------- 1 root root 5970153 Aug 19 17:44 roundcubemail-1.6.0.tar.gz
Things I tried:
