Solved custombuild_plugin.tar.gz: command not found
dmtinc
Chile
When I try to build roundcube I get the following error:
/usr/local/directadmin/custombuild/build: line 7177: custombuild_plugin.tar.gz: command not found
If i check the refered line:
                                if [ ! -s mime.types ]; then
                                        custombuild_plugin.tar.gz "${CWD}/mime.types" "https://svn.apache.org/repos/asf/httpd/httpd/trunk/docs/conf/mime.types"
                                fi
CB Version running on Centos 7:
# ./build version
2.0.0 (rev: 2944)
# ./directadmin version
Version: DirectAdmin v.1.642
Regards
The rev 2944 its the latest version of custombuild
Try re-update it again to the same latest version. There was an error with the build.
Same problem
[root@panel custombuild]# ./build set_fastest
Testing with file 10.kb:
396 B/s         - files-fi.directadmin.com
339 B/s         - files-fr.directadmin.com
345 B/s         - files-lt.directadmin.com
316 B/s         - files-de.directadmin.com
224 B/s         - files-sg.directadmin.com
569 B/s         - files-ca.directadmin.com
Total test duration: 3 seconds
Testing with file 100.kb:
344 B/s         - files-fr.directadmin.com
347 B/s         - files-lt.directadmin.com
386 B/s         - files-de.directadmin.com
199 B/s         - files-sg.directadmin.com
551 B/s         - files-ca.directadmin.com
Total test duration: 4 seconds
Fastest server is files-ca.directadmin.com at 551 B/s
downloadserver is already set to files-ca.directadmin.com
[root@panel custombuild]# wget -O  /usr/local/directadmin/custombuild/build http://files1.directadmin.com/services/custombuild/2.0/custombuild/build
--2022-09-07 10:55:31--  http://files1.directadmin.com/services/custombuild/2.0/custombuild/build
Resolving files1.directadmin.com (files1.directadmin.com)... 104.128.54.74
Connecting to files1.directadmin.com (files1.directadmin.com)|104.128.54.74|:80... connected.
Length: 901480 (880K)
Saving to: ‘/usr/local/directadmin/custombuild/build’
100%[======================================================================================================================================================================================================================>] 901,480     1.15MB/s   in 0.7s
2022-09-07 10:55:32 (1.15 MB/s) - ‘/usr/local/directadmin/custombuild/build’ saved [901480/901480]
[root@panel custombuild]# ./build update
######################################################################## 100.0%
Extracting custombuild.tar.gz...
Cronjob is set for [email protected]:
Cronjob frequency: daily
Automatic notifications: yes
Automatic updates: yes
[root@panel custombuild]# ./build version
,2.0.0 (rev: 2944)
[root@panel custombuild]# ./build roundcube
Found MySQL version 10.4
Granting access: GRANT SELECT,INSERT,UPDATE,DELETE,CREATE,DROP,ALTER,LOCK TABLES,INDEX,REFERENCES ON da_roundcube.* TO 'da_roundcube'@'localhost';
Setting password: ALTER USER 'da_roundcube'@'localhost' IDENTIFIED BY '00000000000';
Editing roundcube configuration...
./build: line 7177: custombuild_plugin.tar.gz: command not found
Fixed in rev. 2945, thanks.
Confirmed, working fine now, Thanks!
Setting password: ALTER USER 'da_roundcube'@'localhost' IDENTIFIED BY '000000000';
