The hour is serious, reflection ...
The back-end script is running automatically with cron, since that I would not suggest using INBOX for teaching HAM. You might do it the way you described, but you should be ready that SPAM messages from INBOX might be learned as HAM.
Yes, it can be like this:
# TEACH SPAM FOLDER
TEACH_SPAM_FOLDER="INBOX.spam";
# TEACH NOT SPAM FOLDER
TEACH_HAM_FOLDER="INBOX.notspam";
I did the test with your script on another server and my BAYES_SPAM and BAYES_HAM to change.
Does this answer my questions for a while?
Other questions
Do you Scan/Learn that returns information to RSpamd or does it do nothing?
Is this on a per user basis, where each user get only his own ham/spam learned and filtered by Rsmapd, or is the ham/spam, which is learned from one user, feeded into the protecting of all users?
Yes, if I understood the question correctly
I also come back to this function:
SpamTally
Some of my messages pass, ad, is on crazy scores is there, no markings, as spam
An explanation
rSpamd uses a global storage of bayes for all users, it's not individual as far as I know. Correct me if I'm wrong please.
When, DirectAdmin create in admin area, like the graphical interface of Rspamd, an interface to manage the spam for spamassassin, it would be idea not ?
What do you think ?
@smtalk
B
hello
@zEitEr
In the settings.cnf file, you can rename the folders as they are defined by default, for example the spam folder?
Mz
