Richard G
Yes +1 on that, we also don't provide or don't want to provide different php versions on subdomains.
			This is just a suggestion...
Is there a market place for 3rd party DirectAdmin themes/skins?
If not... what's the point of having different themes/skins? Why is there a choice to use a particular theme/skin?
If adjustments have to be made depending on which theme/skin you are using, then clearly data isn't being presented to the theme/skin in a way that is universally parseable.
DirectAdmin should just have the one theme/skin and say "This is the way" in terms of panel layout and experience.
I actually can't remember what the theme/skin is or is suppose to be the default one. The default one starts with an E and the other one also starts with an E. If you are running into theme/skin issues and you're using the theme/skin that starts with an E that you aren't suppose to be using - then stop using that theme/skin and switch to the other theme/skin that starts with an E and only use it. Don't like it? Tough.
Unless of course the issues with the theme/skin is the theme/skin that starts with E that you are suppose to be using.
What theme/skin that starts with E are we supposed to be using anyway?
I'm not sure if another setting is needed (although I'm not going to say that it isn't either).We do use PHP Selector. However for a complete user. So a toggle to enable/disable the feature for subdomains would be sufficient.
If you don't use PHP Selector at all you can hide in in the menu. Although this probably would still show at subdomains settings.
The skin - Enhanced - existed for many years (may be near/over 20 years). It is running fine, fast, neat, but not responsive in terms of latest web design.
The skin - Evolution - released in these few year(s). It employs modern design (responsive layout).
There are (or were) a few 3rd party DA skins.
Some admin (like me) likes to use Enhanced.
Any idea why CB shows downgrading for Nginx?[root@myserver custombuild]# ./build versions
Latest version of DirectAdmin: 1.648 build c995cc90e3d5f1c67dd7e9ebb2f7c0fe5d52d585
Installed version of DirectAdmin: 1.648 build c995cc90e3d5f1c67dd7e9ebb2f7c0fe5d52d585
Latest version of Apache: 2.4.57
Installed version of Apache: 2.4.57
Latest version of Nginx: 1.23.3
Installed version of Nginx: 1.23.4
Nginx 1.23.4 to 1.23.3 update is available.
[root@myserver custombuild]# ls custom_versions.txt
ls: cannot access 'custom_versions.txt': No such file or directory
NGINX 1.23.4 is not yet officially available via custombuild and since you don't have custom_versions.txt you are now requested to download to 1.23.3Any idea why CB shows downgrading for Nginx?
@fln is this a know issue at DirectAdmin? It would be nice if at subdomains the PHP version option can be disabled.We do use PHP Selector. However for a complete user. So a toggle to enable/disable the feature for subdomains would be sufficient.
c233e241c2805ccf4d4af2432d0d6f82fab6c474 is released with a security update.This is an automated message notifying you that DirectAdmin has been successfully updated with warnings.
v1.648 (c995cc9) to v1.648 (c233e24)
Warning message:
/usr/local/directadmin/scripts/update.sh (exit status 1):
ef029e9290a15af5cfb41b4a72804aeff23c1c25. The message is harmless but we repacked the release to suppress it.update.sh scipt exits with non-zero exit code. The previous release had a concise bash if clause cmd1 && cmd2. Which when placed at the end of the script reports cmds1 result as the exit code of the whole script. Repackaged update.sh has longer expression if cmd1; then cmd2; fi, which avoids reporting cmd1 status which is used only to check if cmd2 needs to be executed.This is an automated message notifying you that DirectAdmin has been successfully updated.
v1.648 (c233e24) to v1.648 (ef029e9)
Thanks... in the meanwhile NGINX 1.24.0 got into stable (1.23.4 in mainline).@ps4all, we are still testing new nginx builds, nginx 1.23.4 is available on the mirrors so it is available if nginx version is customized. We expect to bump nginx with the DA 1.649 release.
Does this security update also affect stable channel with DA version 1.67?A new buildc233e241c2805ccf4d4af2432d0d6f82fab6c474is released with a security update.
No only DA 1.648.Does this security update also affect stable channel with DA version 1.67?
