DirectAdmin 1.651 has been released
fln
Administrator
Staff member
Hi everyone!
We are happy to announce the release of DirectAdmin 1.651.
The highlight of this release is stability and usability improvements new 3rd party software versions and other fixes.
DirectAdmin 1.651
@fln
Select all button in the file manager is not working anymore in this release.
  • Like
Reactions: fln
It seems Installatron has some issues with the new release in the Evolution skin. The display of available applications is a bit strange. When you then choose Wordpress, the screen remains empty. However, when changing to the old enhanced skin this does work.
Thanks for reporting the issue @exlhost. It is fixed now.
@Shockmedia would be great if this would be reported upstream to the Installatron team.
sorry i have 1 question.
I see directadmin version-1.651 has MariaDB 10.6 updated from 10.6.13 to 10.6.14.
As of now, MariaDB has version 10.11.4.
As follows directadmin is not integrated.
MariDB 10.11.4 is the official version right?
After update We still see this:
Where do you see this. Because I'm trying to get php htscanner working for somebody on php 8.1 and 8.0 but can only install the mod for apache.
PHP htscanner I can save, but if I use the command from the docs to build the php htscanner it says 8.0 and 8.1 are not supported.
So how can be build it now for php 8.0 and 8.1?
Not exactly.. from MariaDB
MariaDB 10.6 is the current long-term series of MariaDB, maintained until July 2026. It is an evolution of MariaDB 10.5 with several entirely new features.
MariaDB 10.11 is the current long term maintenance development series of MariaDB, maintained until February 2028. It is an evolution of MariaDB 10.10 with several entirely new features.
Could be a language issue, but why not just ask when DA will support 10.11? (It's only been stable for five months.)
Bugs.
When I'm in Evo skin and use the search bar for PHP and then select "PHP scripts" then I get an error box:
"Can not execute your request, you don't own that domain"
while logged in as admin, same when using the user level.
Same when using the PHP Settings option, Domain does not belong to you. Also on both admin and userlevel.
@Richard G, both sections seems to work fine on our test machines. Would be great if you could open a support ticket so we could request access and check it on your server.
No idea what just happened, but even though my domain is set to PHP 8.1, it's using PHP 8.2. This was working fine until the recent release. I wouldn't care about it being 8.2 for all the other sites, but some of them use IonCube Loader.
Really odd stuff showing in DA updates too:
Pay attention to the PHP 8.1.. it has 8.2 updated over the top of it and it's saying there's a new version available.. which is 8.1.. something seriously messed up.
What needs to be done to fix this? This has taken down a lot of my sites.
PHP 8.1 service is definitely running.
I tried changing to 8.2 and then to 8.1 to try fix it, didn't work.
I have exactly the same error mentioned earlier here.
Yep, I can't do anything. I've tried even removing PHP 8.1 entirely, rebuilding , rebooting.. re-enabling and the issue just comes back. I have 13 clients who are impacted by this and I will almost certainly have to give service credits.
What the heck is going on here?
When you hover over custom build options, the tooltips no longer display
thanks @alrnetwork, for allowing us to check the issue out on your server. We have resolved the issue. Root cause was customized PHP 8.2 configure script, which forced installing PHP 8.2 files into PHP 8.1 directory. So each time PHP 8.2 was updated it would mess-up PHP 8.1 installation.
@djcart if you have similar issue, please check if you are using customized PHP configure scripts. We recommend using default configure scripts bundled with DA.
I will check on the other servers first to make sure it's not a one server issue and then I will send in a ticket. Thank you.
Any update on post #8?
/usr/local/directadmin/custombuild]# grep php._release options.conf | cut -d= -f2-2 | grep -v no | awk '{ print "./build php_htscanner2 "$1 }' | sh
htscanner is not compatible with PHP 8.0
htscanner PHP extension installation has failed
htscanner is not compatible with PHP 8.1
Oh I thought because of this update:
PHP extension htscanner can now be built separately for each PHP version.
Its build script is updated to avoid build failures when building it for multiple PHP versions at once.
It would apply to all php versions. Luckily the apache mod htscanner is working correctly.
As for the issue, I just checked, I configured all my servers the same, but with Evo is only happening on 1 server. I presume I still need to send in a ticket for it, correct?
