Where did you find that?/evo/reseller/cpanel-import
Importing cPanel accounts can only be done via Admin as far as I know.
Unless somebody created a custom script which resellers can use.
This feature is available on the admin level and on reseller level
which is why I asked where he found that url line.Please make sure it's you who created cpmove-user.tar.gz backup for security purposes, because at this moment we fully trust the content inside, thus available on admin level only. This might change later.
the "cPanel Import" tool
I can't connect to the server at all. I use a reseller account in cpanel and a reseller account in directadmin.
Remote server root SSH credentials are required to perform the import.
You can use the cPanel import tool as reseller from within Directadmin.Any other alternatives?
You don't need to have SSH access in Direct admin, only in cPanel, but not via SSH keys but you need username/password to login from the reseller page as you can see when you open that page.but I cannot authorize access for directadmin
