Using Cloudflare domain Registrar for hostname.
taker18
USA
Hi everyone
I need to understand
I found this https://forum.directadmin.com/threads/directadmin-server-hostname-nameserver-question.61431/
and I added those 3 records as you see, to my surprise no "server.mydomain.com is the hostname and name server.
I thought that shouldn't work.
here is the steps that I did
1- change the host name to server.mydomain.com and NS1 and NS2 update for the new domain
2- updated the DNS record on Direct admin and added to NS1.my domain.com. and NS1.my domain.com. (included the trail dot at the end)
3- checked the directadmin.conf and server.mydomain.com is there the record of NS1 and NS2 are there.
4- made sure that my doamin on cloudlflare record has
Search
Add record
Your search yielded 3 results
Type​
Name​
Content​
Proxy status​
TTL​
Actions​
A
ns1
1.23.45.67
ProxiedAuto
EditWhen toggled open, an additional table row will be added below this row to enable editing DNS records.
A
ns21.23.45.67ProxiedAuto
A
server
1.23.45.67
ProxiedAuto
to be clear
1- server.mydomain.com:222 is working to access DA
2- but not working with mydomain.com:222
my question:
what issue with using Cloudflare domain registration this way?
otherwise, I need to move the domain to another registrar.
any used this methods
Thank you All
Please check list Port supported here.
As you know,
nameserver ( ns{X} ) use port 53
you must grey cloud, if application don't have the ports list that support on cloudflare site.
As you know,
yes agree it works only with the grey cloud. once I turn the proxy doesn't work
I am surprised it's my first time using a domain on Cloudflare as Hostname
I used to transfer my domain to Namecheap in order to make the domain a Hostname because many forums claim that we can not have the Domain on Cloudflare as a hostname.
I hope that I am not missing something, or effect emailing
Depends on how they mean this. Indeed a lot can not have the domain as hostname, because those are different things.
For example. Say you have a domain called domain.com then there are people who want to use domain.com (so the domain name) als hostname. You can't have that indeed. A hostname should be a FQDN hostname.
So domain.com would not be possible but server.domain.com is a hostname, not a domain name, so that is possible.
Probably they mean it this way. It would be rather odd if you could only use the hostname part of a domain name on a server and had to use another domain name for the rest. ;)
If I understand you right, that is the case with me. I am able to use server.mydoamin.com:222
but I am not able to use Domain.come:222 on the Cloudflare case. while I changed the Server's Hostname to sever.domain.com
on my other server I have the domain registrar is on Namecehap which is working : server.mydoamin.com:2222 and mydomain.com:222
both are fine.
well, I don't want to do in this odd situation. Sounds like I need to transfer the domain back to Namecheap or a better provider. it's expensive
@Richard G do you know a good convince domain registrar other than Namecheap it costs $16 for annual renewal for one single domain.
Oh LoL, wel that depends on the domain tld which you are using. Prices went up a lot higher the last years, especially the .com and .org domains.
I see .com renewal is 14,82 in euro's. Same as we pay here. I wouldn't know a cheaper one.
