Terminal feature missing
waragham
i have a problem about terminal feature under "admin" menu.
Some days ago i can use "terminal" feature under my direactmin "admin" login.
But suddenly when i try to use it today, the feature is missing.
Anyone have solution to get back the "terminal" feature on admin dashboard?
I already check & enable "ssh access" on admin account modify but no result, its still missing.
Here i attach some screenshoot about it.
That's odd. If SSH is enabled for the user it should be under System Info & Files in user level.
You have SSH enabled, admin normally has this on by default.
Maybe it's a bug.
Please try this.
Click on list administrators
Click on admin
Click on user button
Click on modify and see SSH Access enabled ?
Please try this.
Click on admin
Yup, SSH Acess already enable but that terminal feature is stil missing.
and check the reseller package
It's admin, not reseller, admin does not use packages. ;)
Yup, i also checking it. Even i activate ssh acces on it. there is still missing.
This is very strange, previously I just had to do a search by typing "terminal" in the search bar and it would appear. But now it's really gone.
I tried creating a new administrator user in the hope that I could use the terminal features on that account. The terminal feature can appear, but unfortunately the access rights are not Root access rights, but only the equivalent of a normal user so you can't do much with it.
Strange. Can you check admins account if SSH is set to ON?
It should be in the /usr/local/directadmin/data/users/admin/user.conf file.
If you can't find it via the search box anymore at -user level- of admin, then I would suggest to send in a ticket. Maybe they have hidden it or maybe something is wrong.
Unfortunately I can't test for you as I only have legacy license.
Yup , i already sent ticket to directadmin support, hope they can help me to solved it.
btw thanks for your help :)
