redis is not working
aryanraj
Custom Build is done and Redis is enabled in custom build (GUI) and domain. However, it is not working.
root@server:~# redis-cli status
Could not connect to Redis at 127.0.0.1:6379: Connection refused
Also, Redis plugin for WordPress failed to connect.
Redis is unreachable: Connection refused [tcp://127.0.0.1:6379]
Redis is not showing in services.
Build log at the end:
make[1]: Leaving directory '/usr/local/directadmin/custombuild/tmp/tmp.09efchX41a.redis-7.2.4.tar.gz/src'
Enabling redis in systemd...
Done redis.
Adjust connection parameters to use a unixsocket connection. This can be done by adding the following content:
define( 'WP_REDIS_SCHEME', 'unix' );
define( 'WP_REDIS_PATH', '/home/<user>/.redis/redis.sock' );
to /home/<user>/domains/<domain>/public_html/wp-config.php BEFORE the last line which includes wp-settings.php.
**Make sure to replace <user> ** with the DirectAdmin user you're trying to configure. Note that the path defined by WP_REDIS_PATH should be the path mentioned in step 2.
After refreshing the wordpress admin page, you'll notice that the connection status changed to "Connected".
appreciate all the help. i fixed it by installing nginx again and then redis.
I have been struggling for hours but you fixed my problem man. Thank you so much!
It worked! thanks bud.
