Thanks, it was set to 3 and changed to 1 now.spam score is around 2.4, but setting required 3.0, trying reduce from 3.0 into 1.0 and testing check log again, it might something anouther issued.
Thank you, but it does the same as the command I gavegrep spamd /var/log/maillog
cat /var/log/maillog | grep spamd only your command is a bit shorter, easier to remember. It doesn't do the same thing in the background. When you cat the file you dump the while thing into stdin and then pipe it to the grep process. Under the right circumstances on a high load and a large enough log you'll thank meThank you, but it does the same as the command I gavecat /var/log/maillog | grep spamdonly your command is a bit shorter, easier to remember.![]()
