strange situation -possible rootkit !?
akadi81
I am using directadmin for many years and right now I have no clue what is going on.
Centos 7 eol, DA legacy.
I have one use account with one mariadb database. There are 2 mariadb users, let say: user and user_db.
And randomly appears a new user like user_uidsniduenjnfndurujdUuYgGyhNj.
This new user has access to user_db database and host is set to localhost and %. The server is binding to 127.0.0.1 only so the access from outside is not possible.
I remove the user and it appears in 1-8 hours.
No rootkit found, no suspect processes found for that user.
No other user with this issue.
I started to log all query and it seems the user is not appearing anymore, so I guess the malware is checking if general log is enabled or not.
OS reinstall in programmed soon.
Any other ideea?
I would like to find the problem before reinstall.
Thank you.
Do you have a passwordless access to phpMyAdmin from DirectAdmin enabled?
Yes. It seems that there is no problem with my user. DA is creating that user for phpMyadmin paswordless crap.
I love it too. But I lost 2 nights verifying every part of the server to find that malware creating strange username. Hosted data are valuable. Is there any mentiona in docs about this behaviour? Anyway, seems not to be a problem. Thank you for the ideea.
same happened here, support confirmed is something normal... i would say those users must be hidden.
