Backups
Pens
Something on my server is creating daily backups, I've checked the host and baclups are not enabled by them.
I've only one Cron job set up and that is to do a backup on the 25th of every month
Although no jobs are shown under the 'all use cron jobs' tab
Anyone any idea whats creating these backups and how do I stop it?
Thanks in Advance
You're a reseller then? Not admin?
You have to let your host check the cron jobs, because the only way to check this out is via SSH.
Another way is to test if there is no bug. It's not the 25 yet, so remove the cronjob and check if backups are still made daily.
Are you sure these daily backups are reseller backups or admin backups and no user backups?
Thanks,
I'm the (only) admin.
I've deleted the Cron job.
cat /etc/crontab
Produces
Nothing there refers to backups, that I can see.
I'm pretty sure they are Admin backups, I'll let you know tomorrow if a backup happens at 05:00
Regards
Nick
Admin backup should locate in "/home/admin/", not do anything with system backup, since there have difference location path.
If something created in "/backup/", then it relate to system backup... maybe you should switch to Evolution skin and re-save system backup again to clean up some broken things.
Ah ok I was wondering because you wrote you checked no backups were enabled by the host.
cat /etc/crontab
Produces
why i that put in there? Because crontab is normally empty and I see "test -x" commands there.
Admin backups (not system backups) would look like this
/home/admin/backups = user level backups of admin himself
/home/admin/user_backups = user backups made by admin (in Enhanced reseller level backups of admin)
/home/admin/admin_backups = backups created via the admin backup/transfer option.
I changed the backup location to /backup, it was easier to SSH to that directory.
Also, I was getting an error message about access when it was set to /home/admin.
The host (Vultr) offer a system backup as part of their control panel.
I've no idea what the test -x commands are
Hello, I'm looking at the backup locations you mentioned and we have a problem here. Our server has several repeated backups, because the admin makes a general backup of all users, the reseller also makes a backup of their users, and the user makes his own backup. We have a lot of storage expenses. Is there any way for only the admin or reseller to make scheduled backups of users and for this backup to be available for the user to restore when they need it? The problem I found in DA is that the admin and reseller backups are not shown to the users.
How do you usually deal with this situation?
Thank you
If I'm not mistaken you already asked that question here but I didn't know the answer otherwise I would have answered there, sorry.
I will give a tip there but I don't think that is what you would be looking for.
I'm just double storage calculation for every user creation.
this ways I can store Admin Backup in the server.
User/Reseller backup always using their storage allocation, so no problem here.
Does the user make a backup whenever he wants up to the limit of the space he purchased?
And in the admin, what would be the backup routine? Would it be a daily backup that always replaces the previous one, and if the user needs it, does he have to open a ticket requesting the restoration?
User/Reseller backup required storage capacity more than 90% of that user. otherwise User Backup won't work anymore and if user have less than 0% capacity, their website won't work and upload or store any new data won't work.
note: 90% can config in "Administrator Settings"
Currently admin backup don't have any rotate backup mechanism, it's just replace on the same filename.
