DA is not executing crons
dorucrisan
Bucharest / Romania
I had to reinstall a server, it is now fresh clean install. OS is Alma Linux. Server hosts a web shop, running some crons to load feed from suppliers every 8 hours. I had that working previously, it also works on other servers in exactly same configuration, exactly same crons. The problem I have now is that crons are not working, none of them, logs are empty. Any ideea what the cause may be? It is related with this new install I think. Thanks.
Als check that crond is running, which should be the case but one never knows.
systemctl status crond
Also check to make sure the user crons actually exist.
