hostname points to wrong folder
Pieter
I'm using my hostname (e.g. host.server.com) as a webhook destination for CSP reports.
Just noticed my hostname points to the following folder:
/home/admin/domains/sharedip/ (here PHP files are printed displayed in plain text)
Previously my hostname pointed to:
/var/www/html/ (with full htaccess and php support).
Note: a few weeks ago I changed the webserver from nginx-apache to apache + did a config rewrite. Not sure if this changed the folder but could be related.
Any tips on how to get my hostname pointing to the default folder again?
Do you have a single IP or multiples ones? If the second you will need to make sure the hostname resolves to the IP that is marked as "server" on a IP management page in Directadmin. If IPv6 is used, then you might need to make sure, it is linked to the server's IP.
Thanks for the reply!
The server has 1 IPv4 and 1 IPv6
Under 'IP Management' the IPv4 is listed as server IP and the IPv6 is listed as shared (linked to the IPv4)
All the best,
Pieter
The DNS A record of the hostname points to the IPv4 server IP, the AAAA record to the IPv6 server IP
The Apache server status page, phpMyAdmin and DirectAdmin can be accessed through the hostname without a problem.
Thanks! Just checked, it is listed as
DocumentRoot "/home/admin/domains/sharedip"
Changing it to the value below fixes the issue.
DocumentRoot "/var/www/html"
Any downsides to changing it to a (probably) non default value?
No, not as far as i know..
I use a hook for it, create a file in /usr/local/directadmin/scripts/custom/ named ipsconf_write_post.sh with the follow content to automatically get changed when changing ip related stuff.
#!/bin/sh
sed -i '/\/home\/admin\/domains\/sharedip/c\\tDocumentRoot \/var\/www\/html' /etc/httpd/conf/ips.conf
exit 0;
My /etc/httpd/conf/ips.conf has a correct path to DocumentRoot "/var/www/html" on a server with single IPv4 and IPv6. If the file content differs on your end it would mean, that you have wrong settings in "IP Manager" in Directadmin. Probably you marked an IPv4 and/or IPv6 as shared in DirectAdmin.
And instead of using patches, you'd better go to DirectAdmin "IP Manager" and remove "shared" flag from IPs.
Removed the shared flag from the IPv6 and did a rewrite config command, still the same...
The IPv6 was also 'connected' to the only 'admin / reseller' account on my server. An additional 'Remove from reseller' was needed to solve the issue!
Many thanks for your commend and fix!
