S sunsunshining Verified User Joined Sep 23, 2024 Messages 31 May 24, 2025 #1 Would you recommend doing that? What is the best way to do it in Directadmin for all domains?
Zhenyapan Verified User Joined Feb 23, 2018 Messages 2,476 Location UA May 24, 2025 #2 as i know it enabled by default, check your /etc/nginx/nginx-gzip.conf and check headers by any online tool that check website speed - it will show if file was compressed and what ratio/archive type
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,168 Location www.poralix.com May 28, 2025 #3 Hello, Gzip on HTTPS traffic can be vulnerable to the BREACH attack depending on your setup and hosted applications. sunsunshining said: Would you recommend doing that? What is the best way to do it in Directadmin for all domains? Click to expand...
